Need some advice on how to disable steering lock without key
On this vehicle that was totaled can find original posts about it here https://www.clublexus.com/forums/gs-...-accident.html
It was illegally towed from my house and just got it back after judge agreed I need to move it but key was in car when it was towed but when they returned it key is no longer in car since i'm parting it out don't want to spring for new key but need to move it so it won't get towed again. but steeringh wheel is locked any way to bypass lock doesn't matter if I damage it. I know this is an odd request but will verify owner of car if needed thanks.
But I see you just had surgery not too long ago so get someone else to do it. good luck with your new GS and hope your doing well.
I'm slowly getting better thanks for concern always make my day better to here positive people. I will try that thanks, would a slam hammer work or dismantling the steering wheel and ignition?
It's hard to remove the steering lock/ignition. They have tapered bolts that needs to be broken off when installed.
If you can remove it then you can steer, otherwise, it's a brute force thing.
how far do you need to move it?
i used to use these
http://www.harborfreight.com/1250-lb...lly-61917.html
http://www.harborfreight.com/2-piece...ies-67338.html
i used to use these
Thanks for the detailed diagram It helps unfourtunatly brute force im lacking right now but i'll try to find someone local who can bust it if cant get the ignition out.
i used to use these
i used to use these
mrBillFL
ES - 6th Gen (2013-2018)
36
02-04-21 06:38 AM
GrrrRx330
04-01-11 02:29 PM
W4SIM
SC- 1st Gen (1992-2000)
07-06-04 03:20 PM
