ABS wheel speed sensor question
I would like to say this site is a blessing. The door acuator help was a huge $$$ saver. Now I have a sensor problem/question. I changed the upper control arm and ball joint on my 01 gs430. Somehow I broke the wires off inside the sensor go figure. I cut it open and fixed it so I thought, reset the ecu and the warning was off for about a minute then came back on. I figured my repair didn't work so I purchased a new sensor and installed it. Same end result about a minute no warning lights then they kicked on. Is there any trouble shooting I should look into I'm at a loss because it was fine until I did the control arm repair and broke the original. Thanks
Was this what you were referring to? I guess I could always take it back out and sand on the knuckle and make sure it's 100% clean.
https://www.clublexus.com/forums/rx-...s-problem.html
Did you verify if the replaced sensor was the problem before you cleared the ECU? Is the replacement OEM? Also, heck and make sure the new sensor is seated into the housing all the way, if its off by a hair it will mess with the sensor accuracy. Make sure the OEM gasket is not pinched eather. Also, are you lowered? Sometimes when your lowered the sensor can get pulled on/yanked out as you turn, etc.
This is why you remove the ABS sensor and place it out of harms way before working on the suspension.
I know it's too late for you but for anyone else reading this it is useful to know.
i agree I even had the suspension supported with a jack stand to prevent it from dropping but I still managed to break it. Think I figured out the problem I'll post shortly if it's fixed.
p092576
Suspension and Brakes
04-28-06 10:39 PM
