Strange whine noise when turning while parked
Old 08-11-16, 09:59 PM
Sanfou510
Sanfou510's Avatar
Default Strange whine noise when turning while parked
Hey fellas something real ****ing annoying is going on with my 00 gs400. I just damn replaced the ps pump with a brand new cardone select brand, Gates high pressure hose, and a reman denso alternator. So whenever i turn while the car is not moving my car makes a loud whining noise, it gets quieter around 5-15 mph then its not noticeable anymore at 20+ mph. The car handles fine and the power steering works. Just cant wrap my head around the whining part. Anybody have any idea to whats going on? Thanks for the help.
Old 08-12-16, 06:15 AM
newgsman
newgsman's Avatar
Sounds like a PS pump issue but have checked out your drive belt pulleys. Two of mine were bad.
Old 08-12-16, 07:49 AM
lexo98
lexo98's Avatar
Did you bleed all of the air out of the power steering pump when you installed it?
Old 08-12-16, 07:55 AM
k7q
k7q's Avatar
Sounds like it still has some air in the power steering system. If you bled it after installing the parts. I would just continue driving it for a couple of days and hopefully the sound goes away.
Old 08-12-16, 12:26 PM
Sanfou510
Sanfou510's Avatar
I went to my local trusted mech and he told me the exact same thing. I'll give it a week and if I still here the noise i'll just bring it to him. Thanks guys!
Old 08-12-16, 07:31 PM
lexo98
lexo98's Avatar
Don't just drive it and see what happens. Check the fluid level and make sure it's properly filled and bleed it while it's parked so you have the opportunity to see if the level drops so that it doesn't go low enough to damage something.
Old 08-14-16, 12:00 AM
Sanfou510
Sanfou510's Avatar
Yeah im checking the fluid levels everyday before i start my car and after my car gets hot. probbably going to bleed it when I am free and see what happens.
lags76
GX - 1st Gen (2004-2009)
01-15-16 12:47 PM
shaft1
12-14-14 07:15 PM
soarerxx
Performance & Maintenance
01-25-07 09:31 AM
walters
04-18-05 05:22 AM
Pagong
Maintenance
12-02-03 10:24 AM
Quick Reply: Strange whine noise when turning while parked
