high output alternator (searched plenty)
Old 07-14-16, 11:55 PM
  #31
SpectraBlu
SpectraBlu's Avatar
Originally Posted by Mr Jokster
Lmfao, I need a t-shirt made with this dude on it.
Old 07-15-16, 07:38 AM
  #32
sakataj
sakataj's Avatar
I believe you have some knowledge in mobile audio, but theres a LOT more to it all. I don't want to continue because I'll bring out one of my famous 5000+ word essays in car audio 101. If one wants something done right, yes, science does have to be involved. There are many people who do audio in their garages, doesnt mean they know whats going on. Merit will be given, because there are some skills involved in fabrication, however I believe installing car audio is the most simplest thing to do, just 3 wires, ANYone can do it. I'm glad you've done competition, its fun and very challenging, but you very well know, competition has nothing to do with reliability, its about forcing it. I've been doing car audio for close to 20 years, owned my own shop and now moved on from it only doing contract jobs for local shops, yet still keeping up with what I can.
Most simplest thing to do huh Nathaniel?
Originally Posted by mizike
Yea I do and not just garage ok systems. Of course you can get super technical but it is a fix. You wire your system with correct Guage wires. You use a stronger battery like an optima for the bass hits that are too strong for your alternator you do the big 3 upgrade and you won't get dimming. A higher output alternator helps tremendously as well with the big 3 upgrade wires. It's that simple and the system is competition level clear with great bass notes. No dimm lights no extra strain on your electrical system which was the issue on the topic. You can get super technical but it is easy. Voltage and amps equal how many watts it supports and the battery covers the bass drops. Up to 2k watts no issues pure clean sound no dimming lights. Use garbage amps. Crap wiring system things get bad quick. Use precision power. Nakamichi or even jl audio or alpine with a solid sub run with the upgrades no issues. That is definitely not 3 wired or that easy either. People mess it up all the time. Run your wires like power and ground on opposite sides of the car. Some use 18 Guage wire for a sub. Or run 1000 watts without the big 3 upgrade and wonder why their lights dimming and they strangle the alternator. This was just the easy basics to take care of the question and reason for the ho alternator and a better battery
i wish you were around to build my system since all i needed was a yellow top, a cheap unreliable alternator and some thicker wires.
Old 07-15-16, 09:52 PM
  #33
mizike
mizike's Avatar
Your going way to far, I have had many incredible systems. Mine right now is a 1000 watt soundstream amp going into a sick 12 inch Soundqubed subwoofer in a custom box, a 1000 watt Alpine amp for my 6 speakers, on a stock Saab 2007 V6 Alternator, Yellow Top battery and only 1 WIRE the positive upgraded from the alternator to the positive, NO DIMMING, every watt goes through, no issues with electrical, no problems and alternator has lasted 3 years no issues. Going to run the same setup in my lexus but with the BNR 200 AMP alternator instead of the stock. The alternator is not cheap, it is also not going to kill the sound system. It is all you need, correct wires, correct guage, solid battery, clean ground, great amps, great sub, nothing extra, system is on point, if your going over 2k Watts then you get a bit more scientific.
Old 07-15-16, 09:54 PM
  #34
mizike
mizike's Avatar
Old 07-23-16, 08:53 AM
  #35
sakataj
sakataj's Avatar
looking back it seems my alternator is a 320 amp and not a 300 for what its worth
Post # 2
https://www.clublexus.com/forums/gs-...-its-done.html
Old 07-23-16, 09:40 PM
  #36
mizike
mizike's Avatar
Yea I saw your ride and build. Freaking awesome. My 200 amp alternator is testing solid from bnr. 14.4 volts. 200 amps at 3k rpms. Fixed my abs issue and error. Should be perfect for the sound system. Can't wait to get min as close to u your setup. Really impressive. I have mine at elite importz now fixing my front door locks. Recharging the ac. Then doing the suspension. Rims. Tires. Tint and then my sound system.
Old 07-23-16, 10:45 PM
  #37
lowKut
NELOC Moderator
lowKut's Avatar
Anyone here actually purchase an alternator from "bnrparts" (Ebay seller)?
I am looking into one right now from them as mine is about to give up after 6 years.
200 AMP for $135.00 cheaper than what I paid for mine when I got it rebuild at 150 AMP.
Old 07-23-16, 11:09 PM
  #38
mizike
mizike's Avatar
Default Yeah
I got mine from them, not off ebay but the site, and they have the newer better 250amp one as well that also fits stock with no alterations. I have a few friends that have them in their cars no issues, one was DOA, got one 2 days later from them, and he has had it for 3 years no issues, the others are going on two plus years no issues. Mine was tested by my mechanic, 14.4v 200amps at 3k rpm, 160 amps at 1800rpm, 150 idle. Its in my lexus, fixed my ABS and electrical issues. They have sold a hell of alot of them and 90 percent or higher have given them 4 to 5 stars, so that and the couple I knew of was enough for me to give it a shot because like you said, MY STOCK BOSCH was going to be 200 bux, I got the built up 200amp from BnR for 170 shipped with a warranty, so not much risk really. Will see how it goes down the road but for the money, the amount of sales, I think well worth it. No like pointed out its not a mechman or DC POWER but they are 400 bux minimum, for the price I dont think they can be a bad choice with a warranty.
Old 07-24-16, 05:34 AM
  #39
lowKut
NELOC Moderator
lowKut's Avatar
Thanks for the valuable feedback. I will give them a call on Monday.
Old 08-24-16, 08:12 AM
  #40
SPRTNYDSN
SPRTNYDSN's Avatar
Sounds like good news However, what do the amperes look like? Voltage is always going to drop, thats not the issue, its how the amperes draw that causes the lights to flicker. I'm curious to see THOSE numbers Most likely though, the dim lights stopped more from the extra juice (battery). Usually the purpose of a high output alternator is so you DONT have to get a second battery I'm very curious to see how the alternator works without the extra juice. Have you taken a long trip bumpin hard for a very long time so you can suck the batteries dry? THAT will test the alternator What equipment are you running? Do you know how many amps your amplifiers draw?
I ran 4 batteries with the stock alternator for 10 years and never had a problem No dim lights or anything because I never drained the batteries enough to run off the alternator.
ok i'm done. I get too much into the science of things.
Oh and... You MUST get that isolator back in there! Or at the very least, run a diode. You WILL destroy your batteries! The ONLY way you can run multiple batteries without them going bad (which is still a bad idea) is to have all of them (or both in your case) be the exact same battery. In short, batteries are not all created equal (even if they're the same model). They all discharge at their own rates, so if you have them wired together and you're playing music or using whatever accessories, one will drop amperes just a little more than the other, so what happens when you turn the car off? The battery that has a bit less juice will suck the juice from the other battery so it will equalize its content, basically they try to charge each other. Now you have 2 batteries with less juice than before. In time of this happening over and over, they begin to lose their charging ability. Especially if you have a deep cycle as an auxiliary battery and a normal starter battery up front.
Hey sorry for the late reply. I can't answer all of your questions but I'll try.
1400W mono amp pushing 2 12" DVC MMATS 3.0
Alpine Old School 4 channel amp pushing 4 6.5" Focal Utopia speakers
LED everything interior.
HID everything exterior.
2nd battery XSPower XP950 is hooked up to the bass amp. No isolator in between that and the main battery.
With all that said, I'm parting out my car anyway but the Mechman alternator and the grounding kit helped out alot. Would
do it again this way.
Old 08-25-16, 09:39 AM
  #41
eicca
eicca's Avatar
The 2UZ alternator might not be that big of an upgrade (130A vs 100A) but I've got one kicking around and I'm gonna see if it fits. On paper all it looks like you'd have to do is maybe grind off one of the extra mounts. Plugs look identical.
Old 08-25-16, 05:12 PM
  #42
mizike
mizike's Avatar
I have no issues with mine so far, running 2000 watt Soundstream amp to my Sub, and a 1000 watt Kenwood amp to my speakers. So pushing about 1000 watts RMS, 1500 watts Peak. No dimming, no extra batteries, both are pretty efficient. I didnt have any dimming or issues on the 120 amp alternator in my saab with this setup either, but put the 200amp alternator in the Lexus just in case and the Sub does hit harder in the lexus. So far I havent needed anything EXTRA outside of the big 3 upgrade on any car staying at 3000 watts and lower.
mcsddd
03-20-16 09:49 AM
srt1
Performance
04-23-15 06:03 PM
Feijai85
CL of Hawaii
03-24-12 02:35 AM
dvsccn
SC- 1st Gen (1992-2000)
07-02-10 08:38 PM
ted920
08-02-06 08:43 AM
Quick Reply: high output alternator (searched plenty)
