How to replace Lower Control arm bushing on Lexus GS300 2003
Is there any way i can replace the bushings on lower control arm without buying a new control arm.
TonyCee (07-27-22)
I bought replacement control arms, but since I had extra bushings sitting around, I first tried to just press out the old bushings. After two hours of screwing with it and damaging the bushings in the process, I just bolted the new control arms in. Based on that experience, and the low cost of replacement arms, I'd go that route rather than spend too much time pressing bushings.
I had both, but still found it to be a PITA. Getting the old bushing out was a breeze, but as I recall, these bushings do not have a lip to press against when installing (in contrast to the caster arm bushings). So as I was pressing on the outer sleeve, it actually bulged, and I could not fully press the bushing in without the bushing mushrooming over the control arm. That's when I threw in the towel.
Today, i took my control arms and 2 new feebest bushings to the machine shop in my area that specializes in press work.
Going in was easy but i was impressed with the method to remove.
The guy pressed out the core, hacksawed a cut on the inside of the bushing outer "race" (30'40 secs of hacksawing) being careful not to cut into the arm.
Then with a hammer and a screwdriver, tapped in the race so it would deformand loose tension and drop out with a little push.
Going in was a breeze as long as the right diameter "socket" is used as the shoulder outside the busjing on the arm itself is so thin.
And yeah i tried pressing mysrlf yesterday and realized I was in over my head as finding the rigjt diameter :sockets were impossible.
