Spacer question
Old 06-04-16, 01:33 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Default Spacer question
Been in awhile since i posted.. Looking at set of wheels that i may run 5mm slip on disk style spacers to get them closer to flush. Will i get any unwanted vibrations? Never ran spacers before.. thanks
Old 06-04-16, 02:46 PM
budgetvip
budgetvip's Avatar
Not if torqued to spec and they fit correctly and center
Old 06-04-16, 03:40 PM
nelson09
nelson09's Avatar
I never trusted those types. Known pleaty of people that ran them for inner clearance without issues though.
I've always ran spacers that bolt onto the hub and are wheel centric. H&R calls them their DRA series, adapters from Adaptec are the same way. That extra little lip centered in the center bore of the wheel gives me peace of mind. Only down side I guess is they arent offered in that application smaller than ~ 20mm
Old 06-04-16, 11:44 PM
tmf2004
tmf2004's Avatar
thans guys.. there was a thread not to long ago that you could buy a set from 5 to 25 etc... I heard anything really over 5mm you should have studs... I should be ok without studs... Need a good brand though,,,
also the spacer needs a lip on it to fit the hub ring for the wheel correct? Where can i get such spacer?
Old 06-05-16, 12:26 AM
Bhubb18
Bhubb18's Avatar
I ran 5mm for a little while, seemed to have no issue. Tried 8mm but studs weren't long enough :P
Old 06-05-16, 12:55 AM
tmf2004
tmf2004's Avatar
did you have studs in the 5mm? i need spacers with the little lip to fit the hub ring..
Old 06-05-16, 01:18 AM
Bhubb18
Bhubb18's Avatar
Was just a stock set up with a 5mm slip on spacers. Not ideal but it didn't give me any issue
Old 06-05-16, 05:59 AM
budgetvip
budgetvip's Avatar
Hit up stancenation and order some 326 power or try central pine and get tdemand if you want the best of the best
Old 06-05-16, 10:52 AM
firelizard
firelizard's Avatar
https://www.motorsport-tech.com/wheel_spacers.html
Old 06-05-16, 01:39 PM
tmf2004
tmf2004's Avatar
thanks guys...
Old 06-05-16, 02:03 PM
Mcon
Mcon's Avatar
tmt2004, You can check this website also, rimspacer.com
Old 06-06-16, 12:14 AM
tmf2004
tmf2004's Avatar
thanks buddy...
Old 06-06-16, 11:44 AM
Mcon
Mcon's Avatar
thanks buddy...
Always buddy. This is why this website is here to help each other.
Old 06-07-16, 06:53 AM
budgetvip
budgetvip's Avatar
Keep us updated on which set you buy I'm thinking of buying a set myself also
Old 06-07-16, 10:37 PM
Zoolander
Zoolander's Avatar
A good set of hubcentric spacers will be all you need. 5mm is about all you can do on stock studs for sure.
Quick Reply: Spacer question
