Aftermarket HU with factory power antenna
Old 05-08-16, 12:38 PM
Polkatulk
Polkatulk's Avatar
Default Aftermarket HU with factory power antenna
I just changed my old Pioneer for a new HU.Now i need to get the powerantenna up.
Can i just put signal power to any cable behind the HU or the Amp,or do i have to build my own "invention"?
Old 05-08-16, 05:43 PM
firelizard
firelizard's Avatar
Does your new HU harness not have a signal wire for power antenna? I think you could use the remote amp signal lead instead, if you don't have one specifically for power antenna.
Also, your 2GS has a power antenna? What?
Old 05-09-16, 01:57 AM
Polkatulk
Polkatulk's Avatar
The HU has a signal cable,but i don't know if there is a single cable in the car or if there is several cables out from the factory radion.
Yes,there us a Power antenna.I think every GS herr in Sweden has one.
Old 05-09-16, 06:30 AM
kamlung
kamlung's Avatar
in the US, the antenna is built into the rear window above the defroster... that is why lizard is probably asking... we don't have a pole antenna on our cars...
Old 05-09-16, 08:13 AM
Polkatulk
Polkatulk's Avatar
I realise that.That's why i didn't find any answer from the beginning.
Old 05-09-16, 01:01 PM
Polkatulk
Polkatulk's Avatar
Oh my! Not just a signal cable here.
Old 05-09-16, 09:22 PM
firelizard
firelizard's Avatar
Oh! Interesting. Perhaps if you are able to identify which wires power the motor, they retain their colour coding when they pop back out behind the dashboard.
These cars are unnecessarily complicated sometimes
Old 05-09-16, 10:51 PM
TW99GS300
TW99GS300's Avatar
If the OEM HU is the same as the Taiwan specs, there should be a 3 pin plug on the back of it. I believe 2 of them will raise the antenna (separate wires for AM/FM) but can't recall. If you use a power meter, you should be able to tell which ones is the positive leads when you turn the AM/FM on. Usually white with black stripe should ground, and it would be to the far right of the plug.
Old 05-10-16, 11:36 AM
Polkatulk
Polkatulk's Avatar
It's 7 pins to the "computer"
I connected the motor to the battery to get it up,now it's up permanent.
Old 05-10-16, 04:13 PM
Bhubb18
Bhubb18's Avatar
Did your one change heights depending on frequency? I've just got mine permanently down since I hardly used AM/FM anyway
Old 05-16-16, 09:00 AM
TW99GS300
TW99GS300's Avatar
Connect it to ignition switched power instead and it should go up and down with your ignition switch. But you should really connect it to the blue trigger wire on your deck.
Old 05-17-16, 02:39 PM
Polkatulk
Polkatulk's Avatar
No,it just got up when i started the radio.
Old 05-17-16, 02:51 PM
Polkatulk
Polkatulk's Avatar
But i don't know where to connect the blue trigger.The motor on the antenna don't stop when it's up.And you have to switch + and - to get it down.
Old 05-23-16, 12:47 AM
TW99GS300
TW99GS300's Avatar
You would need to connect it to the radio side of the harness, not the antenna side. And it should be on an auto timer switch.The blue trigger comes from the new headunit.
xtra
SC- 1st Gen (1992-2000)
06-11-09 02:16 PM
topgun129
08-17-08 07:31 AM
Jmai22
GS - 1st Gen (1993-1997)
01-02-05 08:33 PM
Kyle Harty
12
06-05-03 11:23 AM
Fantius
08-08-02 02:14 PM
Quick Reply: Aftermarket HU with factory power antenna
