Crank Shaft Pulley Wobble HELP!!!
Old 04-12-16, 06:40 AM
STREETGS
STREETGS's Avatar
i replaced the harmonic balancer and problem solved!!!!
VERY VERY easy fix.
just one bolt to remove and swap the new one in.
No more wobble,
Old 04-12-16, 10:04 AM
Mr Jokster
Mr Jokster's Avatar
You had no trouble removing the crank bolt?
Old 04-12-16, 01:19 PM
STREETGS
STREETGS's Avatar
not at all i just
removed the EFI fuse and the EFI relay, (to disable ignition)
put a socket on the bolt attached to a breaker bar
then just gave it a quick crank the pulley turned along with the attached breaker bar
once the breaker bar hit the frame as it turned with the pulley the pulley bolt became loose it lessened
Old 04-12-16, 01:20 PM
STREETGS
STREETGS's Avatar
not at all i just
once the breaker bar hit the frame as it turned with the pulley the pulley bolt became loose it loosened
Old 04-12-16, 01:31 PM
99 GS3
99 GS3's Avatar
Originally Posted by STREETGS
not at all i just
Defiantly an advanced (i.e. sorta dangerous) technique that does work great. Luckily your smart enough to pull the fuelpump fuse, as not everyone is. That beaker bar could cause alot of damage if it slips, or gets thrown out of the bay.
Glad the new pulley fixed your problem tho!
Old 04-12-16, 02:32 PM
Mr Jokster
Mr Jokster's Avatar
Yea, I never thought of removing the relays However, I've never completely turn the key, just snapped it forward then back very quickly till it broke the bolt. Dont think it has to do with being smart though rather than just being conscious about what position your key is in
Old 04-12-16, 03:48 PM
99 GS3
99 GS3's Avatar
haha, the moral of the story is just that one needs to be VERY aware of what they are getting ready to do when they turn the key.
I just picture someone not so mechanically inclined needing to get the pulley loose and his buddy saying "oh I seen on the internet all do is put a wrench on it and turn the key...." there is bit more prep and thought process to it than that for safety of the engine bay and the friends with their heads hovering over the bay watching the pulley when he starts the car..
Old 04-12-16, 03:59 PM
Mr Jokster
Mr Jokster's Avatar
Dude, I'm so with you on that LoL The only thing common about common sense is that its not common! LoL When I first thought about this idea, the first thing that came to mind was, "whats gonna happen if it starts". I so saw things flying everywhere LoL
Old 04-13-16, 08:36 AM
STREETGS
STREETGS's Avatar
yes thats actually what i did i just lightly turned the key,
also i loosely tied the breaker bar to prevent it from flyin out and damaging anything
it all turned out fine. $100 fix not Bad
bwils
11-21-22 05:04 PM
dashan
21
03-10-18 02:25 PM
erock202
Performance & Maintenance
31
11-24-14 12:43 AM
Lowedown
05-05-10 10:30 AM
SC300_704
14
03-14-10 07:19 AM
Quick Reply: Crank Shaft Pulley Wobble HELP!!!
