Don't Forget to Replace Those Balljoints!
Old 04-04-16, 03:49 PM
BayAreaLex
BayAreaLex's Avatar
Originally Posted by mate01
Do these moog replacements need to be greased occasionally?
Yes, they need to be greased periodically. I try to hit them every 2 or 3 oil changes.
Old 04-04-16, 03:51 PM
mate01
mate01's Avatar
Whats the procedure as far as greasing them?
Old 04-04-16, 09:38 PM
BayAreaLex
BayAreaLex's Avatar
umm, they have zerk fittings and you hit them with a grease gun
Old 04-05-16, 03:25 AM
sbagdon
sbagdon's Avatar
In 33yrs of driving Toyota/Lexus (first was a '77 Corolla SR4 "fastback" in '83), I have never, ever, ever seen a catastrophic failure like this, and that's for at least one car approaching 400k miles. I've seen parts that were useless (sway bar links come to mind, that clunk more then do anything useful), yet a failure like this... ouch.
Old 04-05-16, 06:32 AM
dreamcar88
dreamcar88's Avatar
Same here and ive been in the business just as long. I am a service writer so i have seen many things. These have signs of wear . People are ignorant they just chose to ignore the signs of failure and this could happen after many miles of neglect. You should have your front end shaken down every oil change for play as well as check all your tires and tie rods etc.. People are car intelligent so just keep a look out for these things. Preventive maintenance goes a long way. The common is brake pads being no existantant or past that stage where the caliper is blown and they just drive around with nothing.. Never seen a ball joint fail and blow into the fender..
Old 04-05-16, 08:49 AM
BayAreaLex
BayAreaLex's Avatar
For the guys that aren't familiar with this, just look at these pics...
There is a reason why the first thing that this forum tells you to do when you buy a used 2GS Lexus is to replace the lower balljoints.
Attached Thumbnails Don't Forget to Replace Those Balljoints!-bj1.jpg   Don't Forget to Replace Those Balljoints!-bj2.jpg   Don't Forget to Replace Those Balljoints!-bj3.jpg   Don't Forget to Replace Those Balljoints!-bj4.jpg   Don't Forget to Replace Those Balljoints!-bj5.jpg
Don't Forget to Replace Those Balljoints!-bj6.jpg   Don't Forget to Replace Those Balljoints!-bj7.jpg   Don't Forget to Replace Those Balljoints!-bj8.jpg
Old 04-05-16, 09:43 AM
tiguy99
tiguy99's Avatar
Ouch...that happened on my previous GS300 coming out of a gas station on my way to the shop to have them replaced a few years ago...it was a scary learning lesson.
Before I bought my GS400 this week I made sure the owners replaced the ball joints.
If the sellers had no idea what I was talking about I moved on quickly bc their GS is a nightmare waiting to happen
Old 04-05-16, 10:24 AM
bruceb58
bruceb58's Avatar
Why would that be an issue? Buy the car and then replace the ball joints. What am I missing here?
Old 04-05-16, 10:43 AM
tiguy99
tiguy99's Avatar
Not doing a back and fourth.
Meant every word I said
Old 04-05-16, 10:51 AM
SpectraBlu
SpectraBlu's Avatar
I change mine once a year. It might be a little excessive, but $40 and a alignment sounds a lot better than a new wheel/tire, fender/fender liner, and possibly my life or someone else's.
Old 04-05-16, 01:35 PM
sbagdon
sbagdon's Avatar
Wow... impressive photos. Glad to learn something new today...!
Not sure what to do... a set of oem lower ball joints on eBay is about $135, while the upper control arms are $400+ each. Looks like you can't change the upper ball joint, it's part of the control arm.
There's some very inexpensive eBay auctions for very complete kits... upper, lower, links, etc, for around $200. Are you risking replacing those part in a year?
Old 04-05-16, 03:29 PM
SpectraBlu
SpectraBlu's Avatar
Check out moog brand. You can find them at rockauto.com, Amazon, and a few other places for pretty cheap and they're beefier than oem. The upper control arms/ ball joints aren't as sketchy as the lowers, so you don't need to change them as often as the lower ball joints.
Old 04-05-16, 08:00 PM
Mcon
Mcon's Avatar
Originally Posted by BayAreaLex
I am not sure what the lifetime recommendation is from the manufacturer but I do know that a lot of guys on this forum follow ~100K miles or so.
Remember, when one of these goes, it totally takes out the fender and can put your life in severe risk depending on when it fails.
Also, the MOOG replacements come with grease fittings. They also look noticeably beefier than OEM. I have about 30K miles on mine and have been happy with them.
And this happened outside of the city, on the Peninsula. The car did not appear to be lowered.
Best of luck guys!
100% agree with you.
Chech post # 11. Those are moogs with grease fittings. That is what I use for like 3 or 4 years and I'm very happy with it.
Old 04-06-16, 01:15 AM
bruceb58
bruceb58's Avatar
I have no idea what that means.
Old 04-06-16, 06:24 AM
dreamcar88
dreamcar88's Avatar
ill check it out. thanks guys
Quick Reply: Don't Forget to Replace Those Balljoints!
