Tranny flush?
Old 03-30-16, 03:54 PM
mate01
mate01's Avatar
Default Tranny flush?
GS430 with 178k miles. Is a tranny flush or drain and fill more appropriate?
Old 03-30-16, 05:03 PM
Scraape
Scraape's Avatar
i'd say drain and fill for sure. I just did around 5 drain and fills over time on my 98 ls400 and dropped the pan one of those times to change the filter. flushes do a good job of getting sludge out of the tranny, but there is more risk involved when you have a high mileage car.
only use toyota type IV fluid!
Old 03-30-16, 05:07 PM
mate01
mate01's Avatar
Thanks man!
Old 03-30-16, 06:03 PM
lexo98
lexo98's Avatar
I drained and refilled once and that was a bad idea. The new fluid thinned out and I got bad shifts from a cold start. It took a few drain and refills to get it back to normal.
Old 03-30-16, 08:44 PM
bruceb58
bruceb58's Avatar
You can do the drain and fill method or do it the way I do.
Drain and Fill
Remove return line from radiator to transmission.
Run engine until 2 qts come out.
Refill with 2 Qts.
Repeat until fluid coming out is clean.
May take over 12 qts to do this.
Old 03-30-16, 09:09 PM
Scraape
Scraape's Avatar
so....bad idea to switch out old fluid with new fluid, eh? as long as you mix the same type of tranny fluid, you should be fine.
Old 03-30-16, 09:11 PM
Scraape
Scraape's Avatar
Drain and Fill
Refill with 2 Qts.
never tried this before but sounds good. I was under the impression the full capacity of the transmission was ~9quarts?
Old 03-30-16, 09:56 PM
RXGS
RXGS's Avatar
I've always done 2 drain and fills a week apart each year. I get about 3.5 quarts out each time and I feel it's been more than adequate, and I've experienced smoother shifts
Old 03-30-16, 10:17 PM
lexo98
lexo98's Avatar
One drain and refill was the mistake. It takes multiple. At least in my case
Old 03-31-16, 07:07 AM
Debonair
iModerate
Debonair's Avatar
This is definitely an exception, not the norm. There must of been something else at play in you case. A proper drain and fill alone will not cause the issues you were encountering.
Old 03-31-16, 05:26 PM
Bhubb18
Bhubb18's Avatar
Has anyone used anything other the Genuine Toyota T IV fluid? Surely modern ATFs would supersede this standard by now.
Old 03-31-16, 06:48 PM
RXGS
RXGS's Avatar
I've always used T-IV because at my Toyota dealer ts actually cheaper than anything else, but I've seen other people use a Valvoline synthetic with good results
Old 03-31-16, 08:50 PM
GSBeliever
GSBeliever's Avatar
What about a 2005 GS430 with 76k on it, Drain and fill, flush or drop the pan? I've been reading lots of post on this topic lately as my mechanic I use says the trans. fluid is getting dirty and he usually drops the pan for this....Should I just tell him to drain and fill? Former mechanic I had for my GS400 dropped the pan and I could never stop the leak from the pan.... thats my only concern.
Old 05-01-16, 03:25 PM
czr73
czr73's Avatar
Unless your GS is modded, or has Supra tranny, use T-IV. You can never go wrong with OEM.
A drain and fill is the safe way to maintain your trans.
Removing the cooler return line from the radiator is more involved.
The service schedule recommends a trans flush every 60,000 miles.
Old 05-03-16, 03:34 PM
RamAirRckt
RamAirRckt's Avatar
Check fluid level COLD, mine did this for ages till I realized that when COLD the fluid was below the cold line and it WAS the issue. 261k miles now, solid as a rock.
It was good warm, but NOT good cold, and the colder it got the worse
Check it cold, colder the better.
Quick Reply: Tranny flush?
