Need help with air ride setup
If anyone in the 209 modesto, ca area that can help. I lost all power to my accuair setup. Car is in the garage aired out and can not move it, checked all connections and everything looks good but i am not good with electrical stuff.
The wire coming from the battery to the distribution block in the rear should have a fuse up by the battery. If thats fine, then there may be an inline fuse on the switch wire (if its set up only to work while car is on). It all depends on how they wired it, if its independent or daisy chained off other components in the car. If I were closer, I'd swing through and hook you up, sorry :/
feesreveng
05-27-18 04:42 PM
RyGuy0062
11-09-17 09:38 PM
aristonic
09-02-15 01:50 PM
