P0155 Sensor change
Old 02-01-16, 08:27 AM
dvdchance
dvdchance's Avatar
Default P0155 Sensor change
My car has been giving me a P0155 showing Bank 2 Sensor 1. It's a 2002 GS300.
Is the sensor in the pic correct?
What tools will make this easier to replace? Is their a specific socket that works best on these sensors?
Is the correct part Denso 234-4630?
Thanks for reading.
Old 02-01-16, 12:14 PM
GeorgeG5
GeorgeG5's Avatar
yeah, that's it (see attached diagram)
shops sell a special socket to use on these but I'm not sure you'll be able to get it there from top so I'd probably use an open wrench. To make it easier, soak it in WD40 or something couple hours before you remove it to make sure it's not stuck
Old 02-02-16, 07:10 AM
dvdchance
dvdchance's Avatar
Thanks for the reply George.
It looks like it might be more accessible to get a wrench on then I feared it would be. I'm probably going to get this socket:
Amazon.com: Powerbuilt 648442 Oxygen Sensor Sockets: Automotive Amazon.com: Powerbuilt 648442 Oxygen Sensor Sockets: Automotive
Looks like I can get better wrench placement using this then I would be just using the wrench right on the sensor.
Hopefully all will go well when I go to replace it.
Old 02-02-16, 02:52 PM
wbmx1981
wbmx1981's Avatar
It looks like it might be more accessible to get a wrench on then I feared it would be. I'm probably going to get this socket: Amazon.com: Powerbuilt 648442 Oxygen Sensor Sockets: Automotive Looks like I can get better wrench placement using this then I would be just using the wrench right on the sensor.
You should be fine with a wrench. Just soak it in PB Blaster a little before. Good luck.
Old 02-06-16, 08:21 AM
Gdwrench35
Gdwrench35's Avatar
I second the above notion. Use a 7/8 open end wrench and lots of PB blaster. Most of those O2 sensor sockets suck and they stretch and strip the sensor housing. The wrench works better. Especially if you rub a little valve lapping compound on the wrench. No slip!!
Old 02-06-16, 11:05 AM
isfdude
isfdude's Avatar
How to identify which bank to look for. You have to stand and look at the engine with the harmonic balancer facing you. Bank 1 will be on the left side and bank 2 will be on the right side.
Old 02-06-16, 06:12 PM
bruceb58
bruceb58's Avatar
You do realize he has a GS300 right?
Old 02-06-16, 06:59 PM
isfdude
isfdude's Avatar
On an inline 6 engine the bank 1 would be the closest to the front and bank 2 is toward the firewall. I forgot they use the inline 6 for these.
Old 02-06-16, 09:38 PM
bruceb58
bruceb58's Avatar
Why are you posting in the GS 2nd gen forum?
Old 02-07-16, 08:58 AM
dvdchance
dvdchance's Avatar
Well I got around to working on changing the sensor.
You both are very right that an open end wrench fits much better then the socket does. Frankly with the lack of clearance I couldn't use the ratchet if I wanted to.
But after about an hour of trying, it didn't budge not a bit. I used PB Blaster before and during my attempts. I'm hoping it will penetrate into the grooves a bit till I try again in a day or so. Should I keep spraying more or will what I've sprayed already start to work?
Old 02-07-16, 11:02 AM
Gdwrench35
Gdwrench35's Avatar
I would continue to spray it periodically and let it soak in each time. Keep in mind that stuff will burn if it gets hot enough.
Sometimes, taking the sensor out hot makes it easier. Run the car for a while until the engine is good and warm, then attempt removal if you can take the heat.
Old 02-08-16, 01:07 AM
isfdude
isfdude's Avatar
Because I had one 4 years ago and installed a supra 2JZ engine in it before it was wrecked.
Old 02-08-16, 11:39 PM
GeorgeG5
GeorgeG5's Avatar
as Gdwrench35 said, trying to loosen it with the engine warm may be a bit easire, but in this place, you'll probably get couple burns from the piping. Just make sure not to soak it just before the drive
Other stuff that works wonders at loosening seized threads is a brake fluid BUT it eats away paint
Old 02-10-16, 08:32 AM
dvdchance
dvdchance's Avatar
Thanks for all the wonderful suggestions and encouragement. Tried again an hour or so after my drive home from work, got it out and the new one in place. No more P0155 code.
Now to track down the P0430 that is appearing
Old 02-10-16, 08:39 AM
GeorgeG5
GeorgeG5's Avatar
if I'm not mistaken, that's the rear cat... try to check if there's any exhaust leak before it... that can mess up the reading too
Quick Reply: P0155 Sensor change
