Help leaking from ceiling
Got a 1998 Lexus GS 300 and it's leaking when it rains from the spacer between and pillars and the headliner. Could it be because the rubber between the door and the frame of the car or from the rubber between the door and the window? Or maybe on the roof between the windshield and the frame?
Water drips down from there. Anyone know a quick fix while I wait on the part as well? Living in south Florida it rains alot and I don't want to get my seat ruined or the electronics.
Thanks
Thanks
ScWift92 (07-16-23)
Thanks Mcon, doesn't seem to be the sunroof, I poured water through the side of the window and that's when the pillar got soaking wet now does the piece that goes between the door come with the piece that goes around the window as well or are those two separate rubber pieces?
Thanks!
Thanks!
Take that pillar off. Have someone pour water from outside on the top of the windshield. My old gs had the same problem, I used some window silicone sealant on the outside and inside. It worked!
Thanks you guys
Will check auto parts first! Thanks!
I'll check, thanks ISF, after testing everywhere on the car, it's just were I thought, the rubber seal around the door has a small tear, so the water comes into the cabin, down the pillar, pass the tweeter enclosure down to the parking brake pedal.
[QUOTE=Foob;9346207]Well looks like there's a leak from somewhere else too, cause my whole rear drivers side carpet has a pool of water sitting underneath and over the carpet. Now my car smells of mold. Anywhere else I could have a problem with the drains or anything? [/QUOT check your plastic condensation lines that run through the car u need to flush em
