codes
codes
Hello everyone I read everything about this new car I added to my stable bronze brown never seen that color but goes with UPS company so I picked it up. Problem after car was delivered abs code 21 24 vcs 43. Now codes are left rear and right front sensors correct but vcs has me puzzled checked all fuses, so if I fix those two sensors most likely 43 will go because they are connected to problem anybody thanks.
Update on codes its the dreaded brake booster.....dam 2 days already 3k repair job the dealer that I bought it from is helping me so its ok I guess...
Ok sometimes the harness doesn't make full contact with some wires and will get random codes. It worked with my other scion when it gave me abs codes. By unplugging it and plugging it in it will give you fresh contact and you can make sure it's plugged in until it clicks. I've never need a brake booster give any codes at all, there are no sensors around the booster.
ArmyofOne
25
12-28-21 04:38 AM
Lukas99GS
04-29-14 02:45 AM
