timing belt broke at only 75K miles!
Old 11-22-15, 05:24 PM
mulasien
mulasien's Avatar
Angry timing belt broke at only 75K miles!
2005 GS300, bought it a year and a half ago with only 45K on the clock, driving home last Friday I had to accelerate onto the highway. I suddenly hear a loud whining noise, I'm able to pull off where the engine shortly quits.
Diagnosis at the dealer the next day is: broken timing belt, engine is locked up.
Granted, the car was 10 years old, but should that age be enough to have the timing belt break on me 15K miles before the recommended changing interval?
Do I have any recourse for going to Lexus and asking them why a 75K mile engine just grenaded itself on one of their most reliable cars?
Old 11-22-15, 05:51 PM
ThomasGS4
ThomasGS4's Avatar
Strange that the timing belt let go...typically, the water pump will seize before the belt takes a hike.
Old 11-22-15, 05:52 PM
xHyaku
xHyaku's Avatar
Just to clarify, Toyota's timing belt interval is 5 years or 90k miles.
I've also seen it where the water pump bearing was going out and the side to side play shreds the timing belt. Sorry this statement would apply to the V8
Old 11-22-15, 05:56 PM
mulasien
mulasien's Avatar
Interesting, I bought the car a year and a half ago from one of the bigger Lexus dealers in the country. They said they performed a full inspection on the car before selling it.
This is also the same dealer I got service at, and the ones that went "gee, that's the first time I've seen that happen" when I brought it in over the weekend.
Would I have any recourse of going after the dealer if they both sold and performed service on the car and never once 1. checked the timing belt before selling it (well after 5 years of life) and 2. never recommended timing belt service the entire time I brought there for service over the course of my ownership?
Old 11-22-15, 07:39 PM
GSBeliever
GSBeliever's Avatar
Really sorry to hear about your car situation Mulasien. I just bought a 2005 GS430 in March with 68,750 on it and because I didn't have any past maintenance records on the timing belt being changed it was the first thing I did when I had the chance. xHyaku is right, recommendation from the online manual is change every 90k or 72 months although I've read people stretching that out. So when you say engine is locked up, is the engine toast?
Old 11-23-15, 09:10 AM
kamlung
kamlung's Avatar
if you purchased the car there and get it serviced there... i would be nice about it and ask if there is anything they can do to help you... it helps if you have maintenance history with them... the last thing they would want to do is leave a bad taste in your mouth and lose you as a customer and client... perhaps suggest that you would pay up to the amount for a timing belt service, and they cover the difference to get the motor back up and running...
Old 11-23-15, 04:56 PM
BayAreaLex
BayAreaLex's Avatar
Recourse for a snapped timing belt on a 10yr old car that was over-due on a timing belt swap? No.
Sorry to hear about the misfortune. There are countless 200K+ mile 2GS cars out there still on the original belts so to have one go at 75K miles is certainly out of the ordinary.
Let us know what you plan to do.
Old 11-23-15, 06:56 PM
mveale
mveale's Avatar
Pretty much this.
Even though they did an inspection on it, that doesn't necessarily mean that the timing belt didn't appear to be fine. As far as I know, there's no scientific way to test the life of a timing belt, so it's just the technician's opinion following a visual inspection. If it had snapped a few days after you bought the car, you could argue that they botched the inspection, but you put 30,000 miles on it since the inspection. A lot can happen in 30k.
As far as why it was not recommended during your service visits, the timing belt is not readily visible when you pop the hood. There are things that need to be removed to get to it, so it's unlikely that the technician who was doing a 15-minute oil change would pop off the timing belt cover to take a look without a work order to do so, which is something you'd have to ask for.
If you have history with this dealer, I would suggest sitting down with a manager and politely asking if there's anything they can do to help. If that doesn't work, you can start screaming and yelling if you want to be "that guy," but I don't think the dealer is in the wrong in this scenario.
Old 11-23-15, 08:54 PM
SaiyanGS3
SaiyanGS3's Avatar
Sucks but this is on you. Of course age plays a factor. Do 10 year old tires that look brand new dry rot? Do rubber bushings on your car dry rot regardless of low mileage, but high age? The answer is yes to all of this....basically you have no claim to stand on. This is why you always hear that its better to purchase older vehicles with miles on it because these items are typically replaced. You are not gaining anything buying this gen with low mileage.
Old 11-23-15, 09:09 PM
SaiyanGS3
SaiyanGS3's Avatar
Originally Posted by mveale
Pretty much this.
The dealer isn't wrong in this. I'm sorry but the OP's first mistake was letting the dealer do the inspection. For a 10yr old, non CPO car, it makes sense to get an independent person to inspect the car. Honestly what amount of effort do you think they put into inspecting the car? Just enough to make the OP happy so they could sell it to him. I'm sure it passed their visual inspection 30k miles ago, but owners need to be more proactive in maintenance. The OP has nothing to stand on 30k miles later. That is a lot of miles since they sold it to him.
I will say this is the FIRST time reading about a TB snapping. These belts (oem) are usually good for 150k easy....thats if the car is driven regularly
Old 11-24-15, 07:02 AM
mulasien
mulasien's Avatar
Update in case anyone cares: dealer said best they could do was offer some discount on parts and labor to replace/rebuild engine. Not worth the cost regardless to put into a 10 year old car.
A tech at the dealer offered to buy the car from me for $4000 so he can rebuild the engine and re-sell on his own. Took it and got me a 2015 Impala Limited from Car-Max. Big step down in refinement (obviously), but it's very comfortable, gets over 30mpg on the highway out of a 300hp V6, has full factory warranty, and makes for a great highway cruiser.
Time to move on, I guess.
Old 11-24-15, 07:57 AM
BayAreaLex
BayAreaLex's Avatar
I was hoping this story would have a happy ending until I read the part about an Impala. Bummer
The following 2 users liked this post by BayAreaLex:
Bbgnate (04-30-20), NewCarGal (10-21-19)
Old 11-24-15, 07:59 AM
ThomasGS4
ThomasGS4's Avatar
The depreciation you'll get in the first few months could've covered the cost of an engine replacement for the GS300. Just my $.02.
Old 11-24-15, 08:15 AM
SaiyanGS3
SaiyanGS3's Avatar
The new Impalas are actually nice and a HUGE upgrade over our GS
Old 11-24-15, 08:17 AM
mulasien
mulasien's Avatar
Har har.
Of the options available around me for the price range I was looking for and what I was looking for in a car (size, age, driving comfort, etc), it was actually the best option available. This includes the available Toyota options available (was basically looking at a Camry for anything bigger than a Corolla). Impala was roomier, more comfortable, got about the same gas mileage but still had 300hp. No Lexus under 5 years old was in my price range, and seeing that I just got burned on a 10 year old Lexus, it needed to be fairly young with a warranty.
Don't give a crap about depreciation, plan on keeping this car for a while. Also don't give a crap about looks. I'm married with children, who the hell am I trying to impress?
Quick Reply: timing belt broke at only 75K miles!
