help with heat need part number
Old 10-21-15, 06:11 AM
xbajbusx
xbajbusx's Avatar
Default help with heat need part number
Ok 01 gs430 .... the driver side works fine get heat and cold air ...but the passenger side is stock on cold ...I need the part number for the servo can someone help me ....how bad of job is this ??
Old 10-21-15, 06:33 AM
Debonair
iModerate
Debonair's Avatar
Start HERE and keep reading and following the provided links. The part numbers and information on changing them is available.
Old 10-21-15, 08:23 AM
marshun
marshun's Avatar
^i know youre trying to help. i have the same problem. i changed ALL the servos and did the calibration. didnt change. its supposed to start getting cold so this is one of the things im looking into this weekend.
oh the difference is that my drivers side doesnt heat up.
Old 10-21-15, 01:26 PM
Mcon
Mcon's Avatar
Do you check your freon level on your system? In my car long time a go was low freon on the system.
Old 10-23-15, 10:31 PM
Bradlar
Bradlar's Avatar
I am having the same problem with the heat not working on the passenger side only.
I had, had an issue with the passenger side only blowing hot in another Lexus and I was able to resolve the issue by simply cleaning the servo. Tried that with this one, but no luck. The servo did not respond after cleaning and will need to be replaced.
These are the part numbers:
Product #:8710630341, Lexus OEM Damper (For Cooling Unit)
This is the one that controls the temp and is the one that is behind the AC pipes (furthest from you - toward the front of car). It is also the more difficult one to remove, but it is not so bad once you figure out how to get to it. A stubby or flexible screwdriver is a must.
Product #:8710630371 Lexus OEM Damper (For Mode)
This is the servo that will be the one that is closest to you (when sitting in the passenger seat) and most "easy" to remove. This one controls whether the air blows to your face, legs, or defrost.
If you do decide to try and clean it first before buying a new one and simply replacing it you will need to take it apart. This is pretty easy, just a few plastic clips to pry open (try not to break) and then you will need to pull the motor and clean under the large plastic gear with q-tips and isopropyl alcohol. Make sure you take note of where the gear arm is so when you put everything back together it is in the same spot. Do Not try to turn the gear arm with the motor inside! As for the cleaning I would dip the end of the q-tip into some alcohol and bend it so I could wipe clock-wise under the large gear. After cleaning off all the old grease grab some "clean" grease from elsewhere in the servo or from a fresh store bought supply.
When putting the servo's back in make sure to line up their arms with the tracks in place.
What can I say. I like pictures.
Old 10-24-15, 05:57 AM
marshun
marshun's Avatar
freon level has nothing to do with heating. but ive redone the whole ac system. blows a cold *** 30 degrees when its on.
now back to the problem which is the servos not going to where they should on the drivers side to have full heat
Old 10-24-15, 09:35 PM
Mcon
Mcon's Avatar
[QUOTE=marshun;9227449]freon level has nothing to do with heating. but ive redone the whole ac system. blows a cold *** 30 degrees when its on.
marshun,
I can understand what you're saying 100%. But in my case it was that and do not ask me why?? Because in my case was low freon although I do not make sense to me either. I speak from my experience and I just try to help other here, that all.
Old 10-24-15, 10:27 PM
Mcon
Mcon's Avatar
Also, check this website for parts #
https://jimhudsonaugustaparts.com/
Old 10-24-15, 10:30 PM
Mcon
Mcon's Avatar
Also, this one. Good luck
http://www.lexussouthatlantaparts.com/
Rubis
11-07-18 04:23 AM
AKGWBver2
08-17-16 11:43 AM
aneidiaz
10-24-12 09:42 AM
MuGGzyx
SC- 1st Gen (1992-2000)
11-25-10 09:29 AM
meZoom!
09-04-02 02:15 AM
Quick Reply: help with heat need part number
