Surface clean for water pump gasket?
I need some info on how clean the surface on the block of a 1UZ 98 GS400 should be before I mate the water pump gasket to it.
I scraped the mountains of RTV off and then followed up with a razor blade. However, although it is smooth to the touch, there are still a ton of stains from the old sealant. Must this surface be metal clean or is smooth good enough? If needed, how should I get the stains out and have only bare metal exposed? Sandpaper, what grit? Any other ideas.
Thanks, all.
Pic for reference:
Sidenote: I will be using the OEM WP and metal/rubber gasket instead of RTV; previous owner used non oem WP/T-belt and RTV sealant.
Thanks, all.
Pic for reference:
peterls
13
07-31-19 08:27 AM
cnguyen408
09-25-18 05:10 AM
