keyless remote options
Old 07-06-15, 12:19 PM
kameleon25
kameleon25's Avatar
Default keyless remote options
Just bought my wife a '99 GS400. The key was mangled pretty bad. The transponder works but the keyless part does not. Thanks to another thread here I have found a cheap option for OEM key housings. However I am needing the remote portion also. Where is the best place to locate the remote portion? I really don't want to pay $240+ to a dealer for one. I also need a spare for my '01 IS300 and it should be the same remote. So ideally I will need 2. But if they are too much I will have to rethink this. Is there any drawback to using something like this:
Amazon.com: 2 KeylessOption Replacement Remote Head Master Ignition Key Keyless Entry Combo Transmitter Compatible with HYQ1512V: Automotive Amazon.com: 2 KeylessOption Replacement Remote Head Master Ignition Key Keyless Entry Combo Transmitter Compatible with HYQ1512V: Automotive
Old 07-07-15, 09:00 AM
mveale
mveale's Avatar
Hate to be "this guy," but it's often the smallest things that get overlooked... Have you taken the key apart and verified that it isn't just a dead battery in the remote?
As far as non-OEM keys, plenty of people here have used them, so I would try searching the forums and getting some more details. I believe the keys can be programmed by you, just by following instructions that come with the keys. I think there's also a couple threads on this forum with programming/pairing instructions, so I would be more concerned with the cost to cut it. Call a couple local automotive locksmiths and see if they can cut it. If not, call your dealer and find out what they charge.
Old 07-07-15, 09:12 AM
kameleon25
kameleon25's Avatar
It's ok to be "that guy". But I'm pretty sure I need a new key. See the attachment.
I have located what I believe to be a decent set of keys from amazon for $50 for the pair. Plus a local locksmith can cut them for me for $30/key. A lot better than the dealer $200+ per key they want locally.
Old 07-09-15, 12:01 PM
Mcon
Mcon's Avatar
Just in case you need to program your key in the future.
KEY PROGRAMMING for 98-05 gs300 400 430 is a thread here in this forums.
Old 07-16-15, 12:25 PM
kameleon25
kameleon25's Avatar
Just an update on this. The keys from amazon work great! It was a little tricky programming the remote part but the trick was to manually lock/unlock the flip next to the handle, not use the switch. At least that worked for me. Hopefully this helps someone.
Old 07-16-15, 09:00 PM
Mcon
Mcon's Avatar
Thanks for the update. B-)
t2d2
Performance & Maintenance
35
09-23-18 08:58 AM
Pogigreg
09-12-08 07:29 PM
pitmanr200
02-24-08 05:15 PM
GS4IV
12-01-03 06:20 PM
Quick Reply: keyless remote options
