Personal rear light doesn't turn on automatically.
02-21-15, 08:35 PM
Personal rear light doesn't turn on automatically when the door is open. The other side works. Anyone can tell me what seems to be the problem?
02-22-15, 12:08 AM
Probably the door switch.
02-22-15, 06:42 AM
Quote:
Originally Posted by
rgarjr
x2. If you can manually turn the light on, but it doesn't turn on when you open the door, you probably have a door switch issue.
02-23-15, 11:14 AM
3UZFTE
Yes. Exactly. The other works fine. I was working on the interior lights then I had a blown fuse because of the same door. Now when I replaced the fuse, everything worked well except that door.
02-23-15, 05:43 PM
Can you tell me where to locate that door switch that needs to be replace?
02-23-15, 07:17 PM
Patrick92
I have one. Text me 9139542185
02-23-15, 09:59 PM
rbz32
I actually need the information on how to locate it.
02-24-15, 01:44 PM
The switch is embedded into the lock mechanism, so u need to that out to was with the switch.
02-24-15, 03:54 PM
rgarjr
Correct if me I'm wrong, are you referring to the door light? Is the personal rear light on the top connected do that lock mechanism?
02-24-15, 04:11 PM
Switch that turns on/off the top light is in the door latch.
02-24-15, 09:42 PM
rgarjr
is there any guide here on how to fix it ?
02-25-15, 07:51 PM
02-25-15, 08:06 PM
Front door but should be similar
uaaction
06-14-23 02:07 AM
tubenut96
11-04-22 08:14 AM
psls400
09-07-21 03:41 AM
oldschool8
11-25-17 01:56 PM
Gville350
10-10-11 11:20 AM
