Tired of frosted headlights! Aftermarket lens conversion/replacement question:DIY
Did mine a few weeks ago (sand, uv clear) and they looks dang good considering I only spent about $15 bucks in materials. No yellowing, though it might be a bit too early to give a fair assessment.
But It'd be hard to convince me that a new headlight looks that much better than a properly restored one, especially given then cost delta.
I think those headlight "restoration kits" are a rip off. Roll up the sleeves and do it the manly way (lol)
Good luck
Good luck
Wet sanding and polishing headlights can make them look close to brand new but it won't last very long before they get a dull haze. Waxing and sealing prolongs it a little but not much. I even tried Opti Lens but it does not seem to last much longer then a good sealant, the only thing I have noticed is it is easier to maintain with a coating of opti lens compared to just a sealant. After applying opti lens I generally just have to polish the headlights to get them looking almost brand new again, without opti lens I eventually had to re wet sand the headlights to get them to look almost new, polishing would not cut it, but I have not had the opti lens on for as long so I will see.
Does it come with a means to clear coat the lenses afterward? Because if not, it's just as Mr Jokster said and eventually it'll haze again. I used the 3m kit with my previous lenses and while the lenses came out great initially, eventually they hazed again to the point where I purchased new headlights for my retrofit. If anything, a clear headlight film should be used over the lenses to combat the hazing... something is better than nothing.
UDel, what about that 2K clear coat in a can? http://www.eastwood.com/spray-max-2k...t-aerosol.html
blickblock
08-22-18 07:18 PM
