Oil leak help!
Old 08-10-14, 11:48 PM
itztwinki3
itztwinki3's Avatar
Default Oil leak help!
Oil leak can't figure out where's it leaking. All i know is it is leaking from the passenger side of the motor.
Old 08-11-14, 12:39 AM
johhntran
johhntran's Avatar
valve cover gasket, and i would check the vvti pulley seal as well as precaution
Old 08-11-14, 06:52 PM
ttaylor993
ttaylor993's Avatar
Ditto! valve cover gaskets and/or VVT-i pulley. Maybe the cams seals as well.
Old 08-11-14, 11:53 PM
Marklopez
Marklopez's Avatar
Look for the forum I posted. I'm having the same problem. If you take off the covers then you'll see that it's the valve cover gasket. I'm going to attempt to Chang mine next week.
acosta96
07-24-18 04:52 PM
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
itztwinki3
09-08-14 07:31 AM
saleen90
01-06-14 08:39 AM
Sick03L
02-24-12 04:35 AM
Quick Reply: Oil leak help!
