VSC VSC Off light on
Old 06-10-14, 01:13 PM
pinoiryder
pinoiryder's Avatar
Default VSC VSC Off light on
I just change my rear brake pads and now why VSC and VSC/OFF light are on? Any idea what triggers this?
Old 06-10-14, 01:35 PM
bonesnj0
bonesnj0's Avatar
Get code reader read code then post back!
Old 06-10-14, 01:37 PM
bonesnj0
bonesnj0's Avatar
Or go to auto parts store let them read codes.
Old 06-10-14, 01:59 PM
iToaster
iToaster's Avatar
Sounds like one of the wheel speed sensors got messed up while installing the brakes.
Old 06-10-14, 02:13 PM
offbad
offbad's Avatar
i agree probably the sensors. did you cut/smash/rip them?
Old 06-10-14, 06:14 PM
pinoiryder
pinoiryder's Avatar
there is nothing to smash/cut/rip/bump as the only line connected on the caliper is the brake line hose.. I did i run the car for a while and clear the codes.. so far i have not see the VSC/VSCoff light..
Old 06-10-14, 06:15 PM
pinoiryder
pinoiryder's Avatar
Default No sensor attach
there's no sensor attach on the rear brake..
Old 06-10-14, 06:16 PM
pinoiryder
pinoiryder's Avatar
I have a bluetooth OBDII code reader.. forgot to post the code it was throwing..
Old 06-10-14, 06:24 PM
iToaster
iToaster's Avatar
There's one close by in the hub, you might have inadvertently upset it somehow during the brake replacement process.
Old 06-10-14, 06:27 PM
pinoiryder
pinoiryder's Avatar
Let me check on that.. I clear the codes and have not seen it again after driving for a while..
Old 06-10-14, 07:27 PM
offbad
offbad's Avatar
nope there definitely is one for each wheel; perhaps there's your problem.
Old 06-10-14, 07:28 PM
offbad
offbad's Avatar
if the codes went away you're probably fine.
Old 06-11-14, 11:37 PM
pinoiryder
pinoiryder's Avatar
I just check it and and found the sensor.. I check it and nothing has been move.. so decided to remove it and inspect it.. there are some grease on the sensor itself and clean it.. run the car and i have not seen the the VSC VSC/OFF light on.. will monitor it.. thank you all for the info..
DaveN
05-09-20 07:55 AM
SebCypher
10-18-17 08:44 PM
Gocards6
05-06-17 04:49 AM
xuserx04
01-11-10 05:09 PM
Quick Reply: VSC VSC Off light on
