APP Sensor
Old 06-01-14, 02:02 PM
tn96dc
tn96dc's Avatar
Default APP Sensor
Is it possible to have a faulty APP (Accelerator Pedal Position) sensor and not trigger the MIL or any codes?? I'm having symptoms like a faulty APP sensor on my 2002 GS300. Any input would be great!
Old 06-01-14, 06:03 PM
rgarjr
rgarjr's Avatar
What kind of symptoms. Are going into Limp Mode? I'm having problems with that right now as all.
Old 06-02-14, 12:26 AM
tn96dc
tn96dc's Avatar
I'm not going into limp mode but I get the hesitation off the line and at cruising speeds i can feel some jerking/bucking at low throttle. I also get horrible fuel consumption.
Old 06-02-14, 12:58 AM
NorthStyle
NorthStyle's Avatar
Have you tried cleaning your MAF sensor? When my pedal sensor was on it's way out, the only symptom I had was that the pedal would take more effort to keep the speed up, but it would go back to normal if I just took my foot off of it for a second or two.
I didn't have any hesitation or bucking though.
Old 06-02-14, 10:12 AM
burny
burny's Avatar
With certainty I can tell you codes may not be thrown with faulty APPS or TCM. I had it happen with both at different times. No codes, but the dreaded limp mode to point of almost causing me to get killed. I checked the sensors with a multi meter and narrowed it down each time to what it was. The TCM sensor hangs right above the manifold on a little bracket. It is exposed to a lot of heat and I'm sure that is causing failure over time. I have replaced 2 of those during the life of the car. It has beeing running like new the past year with zero issues. 140k on it. 2002 sports design GS300 Graphite Gray Pearl
Old 06-02-14, 11:19 AM
rgarjr
rgarjr's Avatar
Yeah that area does get really warm for some reason. Cant be good for the throttle control motor or the Apps sensor.
Old 06-02-14, 12:29 PM
tn96dc
tn96dc's Avatar
I've replaced the MAF with a new one from Lexus/Toyota. Seemed to run a bit better but not for long.. lol
Does this look like a normal reading to you guys?
Old 06-02-14, 12:30 PM
tn96dc
tn96dc's Avatar
Did you have to calibrate anything?
Old 06-02-14, 02:54 PM
burny
burny's Avatar
do that check on the Throttle control motor and the Throttle position sensor. The APPS seems within limits.
Old 06-02-14, 02:58 PM
burny
burny's Avatar
https://www.clublexus.com/forums/per...p-mode-23.html
There is some great information in these 32 pages. Somewhere in there is a PDF attached that has all the Lexus specs on the 3 sensors mentioned. I learned a lot from it when I had issues.
Post #161 and 162
Old 06-02-14, 03:03 PM
burny
burny's Avatar
Another thing. You do know Lexus will fix these issues for free now after the class action lawsuit. If they have not been replaced before, call Lexus and tell them your issues about acceleration problem and mention class action lawsuit. Some folks on here have had it done for free recently.
https://www.clublexus.com/forums/per...nsor-help.html reAD POST #9. you can thank me by hooking me up with that chick in your avatar.
Old 06-02-14, 11:51 PM
tn96dc
tn96dc's Avatar
Thanks burny, I'll comb through these treads. I don't think you want her after I'm done with her LOL
user 528962307
Performance
12
10-30-19 11:05 PM
yungtrinib
08-28-18 09:02 AM
dlamb89
06-13-15 04:22 PM
treimche
01-15-07 06:25 PM
Quick Reply: APP Sensor
