double din help
Old 04-26-14, 08:03 AM
l3lackros3
l3lackros3's Avatar
Default double din help
so i just go a DD on sale nothing to fancy but it has everything that i need. I was told to buy a harness connector and to bypass the amp with it but not an expert in stereos so i require a little help. would it be better to connect it with the connector or just cut wires and join them together? and if anyone knows where i can a find a wiring diagram that would help a lot.
Old 04-26-14, 11:13 AM
tereck
tereck's Avatar
Get the connector don't cut the wires. That's what we call a micky mouse . On the connector should have the remote to turn on the factory amp. Don't cut the wire just bypass it. Good luck
Old 04-26-14, 11:30 AM
NorthStyle
NorthStyle's Avatar
Like tereck said, just use the harness. In addition to that, there's a link to installing an aftermarket receiver in the DIY post: https://www.clublexus.com/forums/gs-...ou-search.html
Old 04-26-14, 12:29 PM
ToddK
ToddK's Avatar
Are you thinking about going with an aftermarket amp/sub? You are going to want some bass, it sounds really bad without anything. Definitely use the harness for the radio (I believe you just use half) and then bypass the amp. I bought a cheap amp to push the factory sub. I didn't want a lot of bass (it still sounds good) I didn't want to relive my high school days and lose any more hearing!
Old 04-27-14, 01:12 PM
nezlyfe
nezlyfe's Avatar
I have an AVIC D3 and I spliced the wires but I also rewired the stereo and have 2 amps in my car. If you want to just install the headunit and don't plan on upgrading everything else don't cut the wires and buy the harness.
Old 04-28-14, 03:01 PM
l3lackros3
l3lackros3's Avatar
thanks for the help! everything is done after a few hours of screwing up -_- just waiting for my dash kit to arrive in afew days
Old 04-30-14, 07:24 AM
mkpoto
mkpoto's Avatar
thanks for sharing the link!
cormier88
SC- 1st Gen (1992-2000)
12
05-04-11 08:00 PM
02msmg3
02-20-11 12:46 AM
ypv123
05-29-10 09:11 AM
vinsin31
03-13-10 02:28 PM
Quick Reply: double din help
