transmission oil cooler hose from radiator?
We're interested in knowing how this works out for you. Let us know whether the cooler was leaking fluid into the radiator. That's good info for the forum. Also, keep us posted on the tranny flush. Let us know if it leaks or slips.
well the mechanic flaked on me. and shops do not want to touch my car because of high millage due to there warranties. i bought 2 jug of coolant. 50/50. i took my radiator off and filled it with soap and let it sit for a hr...
i block one side of oil cooler and i blew in the other.. no sign of leaking... So now im thinking its not my oil cooler leaking? maybe just super old oil from maybe a bad HG from previous owner. and they maybe didnt flush the oil/coolant in block? anyways.. i couldnt find the drainage on the block. so i just connect everything back and refill it with new coolant.. and once the car warmed up and coolant flowing around. brown stuff came out again. im thinking its the old old fluid in the block or something..
The head/ waterpump/ timing belt/ looks new...compare to everything else. so im assuming the car recently had a bad hg, and the old coolant/oil is still in bottom block?...
http://search.aol.com/aol/imageDetai...in+plug+on+2jz
crapp.. i guess i need to waste another 20-30 bucks on coolant if im going to flush it out of the block also.. thanks ttaylor your the MAN! i havent check my radiator flush. i will recheck for brown and post pics. maybe it is a crack somewhere or hg. -_-
lexixel
02-01-16 11:22 AM
gs2impress
GS - 1st Gen (1993-1997)
10-22-10 02:53 PM
