98 GS300 Idling and Starting Issue, list of new parts
Old 03-29-14, 08:44 PM
  #31
chrcrou26
chrcrou26's Avatar
He's right it could simply be the butterfly valve seizing
Old 03-29-14, 10:11 PM
  #32
Justin2JZ
Justin2JZ's Avatar
Originally Posted by chrcrou26
Noid light is only gonna show electrical problem which he'd already replaced everything you can under the hood
The Noid light will detect if the injectors are pulsing or not.
Old 03-29-14, 10:58 PM
  #33
chrcrou26
chrcrou26's Avatar
Ic what your getting at but injection problems aren't intermittent....There either pulsing or not....so wouldn't explain fluctuations in starting with a rough idle then running smoothly and carrying an idle...The symptoms just don't match up with that
Old 03-29-14, 11:07 PM
  #34
chrcrou26
chrcrou26's Avatar
Also injector issues would throw misfire codes he has none
Old 03-31-14, 06:24 PM
  #35
Relex
Relex's Avatar
Thank you, I just got a second throttle body , nothing. got a new tps and accelerator pedal sensor..
nada... I cleaned all connectors and checked for leaks...nada
I did get P0171 to come back..... I dont know why its back.... Fuel pump, pressure regulator and dampener are new... I am not getting enough fuel or have a air leak...or its electrical....
I took a photo of some capped nipple on the throttle not sure if that is stock....
only thing left now is maybe ECU..... can I rule out fuel pump, pressure regulator or throttle...
I also don't know what that actuator thing in the second picture is...
dont know why I am running lean.... anyone know any good mechanics in Chicago?
Attached Thumbnails 98 GS300 Idling and Starting Issue, list of new parts-20140331_184614.jpg   98 GS300 Idling and Starting Issue, list of new parts-20140331_184631.jpg
Old 03-31-14, 06:44 PM
  #36
chrcrou26
chrcrou26's Avatar
There's a vac hose running from Lil black box next to your throttle cable....should run towards the drivers side and then straight down and connect to a much stiffer lone connected to the exhaust somewhere I believe....mine disconnected the other day and I noticed some irratic idle but I caught it quickly so idk if it could have caused the problems ur having if I'd not found it worth a shot though to check
Old 03-31-14, 06:47 PM
  #37
chrcrou26
chrcrou26's Avatar
Is there anyway you could post a video of what your experiencing also....we might see or hear something you don't
Old 03-31-14, 07:02 PM
  #38
Relex
Relex's Avatar
confused, I don't see anything by the throttle cable ,or disconnected, cracked or loose, just that one capped tube that i circled... not sure if its capped stock or it normally has something running to it.
thank you, I will try to get a short video up or at least better pics...
thanks for your help
Old 03-31-14, 07:12 PM
  #39
Relex
Relex's Avatar
i know that in 99 they used two different types of fuel pressure regulators, around mid year they had a revision I think, trying to think if I have bad fuel delivery or a mysterious air leak...injector o ring maybe?
if that fuel pressure or air leak is it possible my electronics are bad... like a leaking transistor in ECU....
if I move the TPS i can get it start right away but I do get CEL for lean bank 1 (P0170)
biggest problem is that car dies and sometimes shakes at 1000+ RPM,
can a bad oxygen sensor or idle control motor do that? just so I can start ruling things out....
Old 03-31-14, 07:21 PM
  #40
chrcrou26
chrcrou26's Avatar
This is bothering me now lol....The reason I think it's a air leak is you iacv tells the ecu what to do and I'm pretty sure you replaced yours....but that's what seems to be the problem maybe a bad maf....but any air leak would drive ur iacv crazy and idle all over the place or in your case not run at all
Old 03-31-14, 07:24 PM
  #41
chrcrou26
chrcrou26's Avatar
You took the words outta my mouth lol just looked at the leaking capacitors in ecu post myself
Old 03-31-14, 07:34 PM
  #42
chrcrou26
chrcrou26's Avatar
O2 sensor no...iacv yes...
Old 03-31-14, 07:49 PM
  #43
tereck
tereck's Avatar
I don't know if it helps. But I have a gs400. V8. I have a p0171 bank 1 system too lean. I almost run out of options to replace . O2 sensors .maf. Gaskets. Iavc. Tps. Flush fuel system . Blah . Blah. Blah.
In my case what is throwing that code it's my cold air intake. Maf it's detecting more air on the intake manifold. That's my problem. did u have an aftermarket cold air intake? ?? Dirty maf?
Old 03-31-14, 08:08 PM
  #44
Relex
Relex's Avatar
thank you
i can try getting a new idle control motor because the TPS and the MAF are straight from Toyota and I also have aftermarket backups that work the same once on the car.
I can try replacing the fuel pressure regulator and pump but that wouldn't make sense, right? what about a small fuel leak causing me to drop in pressure? if not can I rule out the whole fuel and ignition systems? that leaves electronics and air leaks... what about a relay?
( I did change most fuses...) throttle body is spotless and I also have a spare...
anyone know idle control motor toyota part # also ECU part # for 99...
Old 03-31-14, 08:31 PM
  #45
chrcrou26
chrcrou26's Avatar
Yours just need and ecu adjustment.....have to do the same thing with and art intake.....just a Lil remapping
Quick Reply: 98 GS300 Idling and Starting Issue, list of new parts
