2000 GS400 spark plugs?
I've done a search but haven't found the answer I'm looking for yet. I currently have NGK IFR6T11 plugs in my gs400 and am thinking they may be due for a change, tune-up. Is the iridium plugs worth the $8.99 per or would the Denso PK20TT at @2.99 or NGK G Power at $3.29 be ok for a daily driver?
All are listed at Advance auto for the gs400, just not sure if the performance/mileage or the car will be effected by a cheaper plug?
Thanks
Thanks
From my experience with ignition, it's always best to put whatever the car called for from the factory back in. Unless the plans are to heavily modify/change fuel management of course. Every manufacturer tends to use certain brands (Toyota/Lexus = Denso/NGK, Dodge = Champion, Europeans = Bosch, etc)
Like TMF said, any Denso/NGK Iridium plug # should do the trick, or just get the same ones you pulled out
