Speed Sensor
Old 02-22-14, 12:24 AM
Aristo722
Aristo722's Avatar
Exclamation Speed Sensor
Now I know the ABS sensor is the same thing as the Speed Sensor. There are 4 of them located in the wheel wells. But, I'm wondering, is there a speed sensor in the rear by the differential. Wouldnt that be the sensor that controls the speedometer? The problem I have on my 02 GS is, I have VSC, VSC OFF, and ABS lights on the dash, the speedo is stuck at 0 and the Odometer is not incrementing. So wouldn't I just have to replace the speed sensor in the rear on the differential? Or is it the ABS sensor that controls that and needs to be replaced?
Old 02-22-14, 07:52 PM
Aristo722
Aristo722's Avatar
Bump for help... please
Old 02-22-14, 09:02 PM
Lexilux
Lexilux's Avatar
I don't know if this will help you and I don't know much about these cars but I do know that there is one on the transmission. A bad vehicle speed sensor took out my speedometer, made my abs act up and made the transmission to go in to limp mode. It is easy to see as it is in a little recessed area on the transmission of my 99 gs400.
Old 02-22-14, 10:09 PM
Aristo722
Aristo722's Avatar
I guess that might be the problem, Ill look into it and hook a scan tool to it.
Old 02-23-14, 09:38 AM
porn-adkt
porn-adkt's Avatar
Start by getting the Codes.. Go from there. Speedometer on Cluster may also be dead
Old 02-24-14, 07:35 PM
Aristo722
Aristo722's Avatar
Speedo ins't dead, the ODO isnt moving. The code means bad speed sensor, what im trying to figure out is, which speed sensor needs replacing.
Old 02-24-14, 07:59 PM
tiger4life
tiger4life's Avatar
Probably the ones one the transmission (I think there are 2). The one at each wheel are only used for ABS/traction control I believe.
Old 02-25-14, 01:51 AM
Aristo722
Aristo722's Avatar
Same thing my Automotive teacher told me. He said the speed sensor that controls the speedo needle, is the one on the trans, by the diff. Guess Ill get that replaced then!
Old 02-25-14, 06:40 AM
gsbs300
gsbs300's Avatar
The abs sensors are wheel speed sensor.now the sensor that your odo gets live reading from is in the trans and it is just called the speed sensor,not wheel speed sensor.i care to say you have two problems because my wheel speed sensor is out causing my abs vsc and vsc off light but my speedo obviously still works.your going to need a good scanner to know what sensor at which corner of the car is out (my cheap one doesn't tell me).but as far as the odo not working my bet is on SPEED SENSOR.hope this helps
Old 02-25-14, 06:47 AM
wbmx1981
wbmx1981's Avatar
The speed sensor is on the driver side of the transmission held on by a 10 mm bolt.
Old 02-25-14, 11:14 AM
Aristo722
Aristo722's Avatar
And the SPEED Sensor is the one on the trans, driver side. That has to do with the Speedo and Odo Reading. I have VSC, ABS, and VSC OFF lights on my dash to. I do have a snap on scanner that could probably tell me which all needs replacing, Ill have to run my lexus out to the shop and hook it up. So Im sure I need the Wheel Speed Sensor replaced, and even the Speed Sensor on the transmission. Jesus. :'(
Old 02-25-14, 12:29 PM
gsbs300
gsbs300's Avatar
Yea they are both pricey,and used parts is just setting yourself for failure.i just paid 145 for front passenger wheel speed sensor.
Old 02-25-14, 02:55 PM
Aristo722
Aristo722's Avatar
Yep, gotta do what you gotta do.
Old 03-04-14, 05:46 PM
Aristo722
Aristo722's Avatar
So Since the speedo and ODO are not moving, to fix that is just replacing the vehicle speed sensor. There are two located on the transmission. One in the front, one in the rear. Which one needs to be replaced? That scan tool does not specify which one. I have a diagram that shows the veichle speed sensor, number 8 up at the top, not so sure if you can see it... Anyway, is that considered the one in the "front" of the transmission. They are both female connectors. Anyone might have some insight on that?? Before I go to replace anything, Ill try giving them a clean first, but if worst case scenario and they need to be replaced...
Old 03-04-14, 05:47 PM
Aristo722
Aristo722's Avatar
Here is the Diagram. Number 8 at the top is what Im asumming is the front. Then one in the back by the diff. My question is, which one needs to be replaced to get the ODO and Speedo moving again.
Quick Reply: Speed Sensor
