how do i fix this?
Old 12-22-13, 04:02 PM
gstreee
gstreee's Avatar
Question how do i fix this?
beam output is all over the place both in hid headlamps and fogs.....wth how do i make it level again? pic attached
Old 12-22-13, 07:27 PM
1sWt2GS
1sWt2GS's Avatar
google man.
its just a screw in the engine bay..
heres a legit PDF that explains it though.
http://us.lexusownersclub.com/forums...ght-alignment/
you'll need to make an account and log in to DL it
Old 12-22-13, 09:10 PM
raytseng
raytseng's Avatar
depends why this happened in the first place.
If you replaced bulb and this happened, the bulb might not be seated right
If this happened all of a sudden, the auto-level might be messed up.
If otherwise this has been the way it was, you can just use the manual leveling.
Old 12-23-13, 11:51 AM
aneidiaz
aneidiaz's Avatar
I have this issue too. But I crashed my driver front side last year. Little sign been coming up on & off for the leveling motor on dash to my understanding. When I replaced my old lights with the new, the auto leveling motor was attached to bottom of the headlight. If your going to attempt to change out auto leveling motor, do it comfortably. Remove front bumper and remove headlight. Get a complete view of the actual part and learn what your working with. It's an easy fix with patience and a few hours, no rushing. I hope your problem is resolved and your lights shine evenly as you want!
JohnnyTCEO
06-26-22 05:11 AM
Louielex
04-16-19 08:39 PM
XCLSVELS
04-22-13 08:21 PM
gapxguy
08-31-05 01:56 PM
Quick Reply: how do i fix this?
