Removal of Driver Side Fuse Box HELP!!!
Can Somebody please tell me how to remove the Driver Side Fuse box/with the body ecu attached?? I tried to get in there but it seems like no room at all. If someone has an easier way, Please share.
Damn, I can imagine that is a whole lot of work. And the bad thing is that I just want to check my body ECU for a ground connection. Maybe ill check the driver door ecu first.
Okay, will do. The same ground wire(green) from the body ecu should be in the door ECU right. When you say check? What exactly do you mean? Take it out/apart or check continuity?
I am taking everyones advice. I am now asking how? I understand to swap out, bit I have to go and get another one first. So I would to know how I can diagnose the one I have. I understand that I might have a ground issue. Just trying to learn here,that's all
Has anyone came up with a way to remove the fuse box? Without removing the whole dash assembly. I was able to remove the screws and disconnect the the front wire harnesses but I could not get it to move. Any advice would be great
