Intermediate and inconsistent wobble on one wheel
Jokster did you ever figure out the problem? I'm experiencing the exact same problem, and i've already replaced the lower ball joint, upper control arm, and steering rack bushings. I had high hopes that it was the #2 arm, but after finding this thread i'm less optimistic. It drives me insane that my gf's 99 camry drives better, please help.
Also if you over torque your lug nuts it causes the rotors to become warped from over torque ive been working on cars for Over 20 years and had the same problem and my lexus mechanic mentioned the over torque of lug nuts so i replaced my rotors and properly torqued lugs and wouldnt you know no wobbles
Throwing my stocks on wont say anything. If wobble went away, just means that whatever the problem may be, it doesnt like weight on it. Moving wheels wouldn't help anything either, I already concluded its not a wheel problem since it follows to a total different set.
Before you switch the wheel bearing, you can throw a torque wrench on the suspect wheel bearing and re-tighten it. If it's loose-ish as in not being fully tight, it's a sign of a bad wheel bearing. Often times re-torquing will temporarily tighten it back up. If that solves the problem for a short time, you know it's the bearing for sure. If the bearing is fully torqued still. I question whether it's really bad.
I assume you have hub-centric rings on these wheels right?
Also, I'm getting a very intense vibration/wobble/bounce type feeling when I hit about 65. I just got done changing my rear struts (thought the vibration was in the rear). Like you I don't want to keep dumping money into guesses. The description of your symptoms seems pretty close to what I'm feeling in my car.
5% Club. Killing it!!!
BIGVIC23
Suspension and Brakes
67
01-26-12 01:37 PM
