Steering stiffness and Steering ECU?
Old 05-16-13, 12:40 PM
RamAirRckt
RamAirRckt's Avatar
Default Steering stiffness and Steering ECU?
I have found many threads and people complain what looks like most all years of the GS steering being too light.
The odd thing is my 98 GS4 has always been on the stiff side. Stiff meaning you AREN'T going to comfortably drive the car at slow speeds with one finger. My wife complains that she doesn't like driving my car because the steering is too stiff.
I have driven many cars of the years and I can say my GS (VIN under 4800, so an early model) is far from light steering. I don't complain, except at slow speeds you need to 2 hand it if you are going to turn it fast and tight turns.
Wondering if the early GS's were stiff and they did a running production change for the light steering and went too far?
Anyone with an early 98 GS4 think the steering is too light?
I have changed the ball joints in the last 8 months and has RP synthetic fluid in the PS, which I am going to change here this weekend again.
Old 05-16-13, 02:08 PM
NukedGS300
NukedGS300's Avatar
Before i got my 2001 GS300 I had a 1997 Chevy Silverado with a bad steering rack. It was sloppy and all over the place. I love the stiffness of my GS.
Old 05-16-13, 03:31 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
i have to say that i experience the the same stiffness at low speeds but seems to loosen up at great speeds like 60 + and then the shaking starts... at 80 its fine... I've just done ball joints as well so i'm sure other parts are worn and in need of replacement... The last couple days i've thought about the steering rack as well...
Old 05-16-13, 04:23 PM
SprtDesign
SprtDesign's Avatar
I've dealt with the frigging loose steering and 60-70mph steering shake for months. Two sets of rims and tires alignments, ball joints, etc.. Well as of yesterday NOOOOO SHAKE!! Hallelujah!
I must have caught the tech on a good day. Had the car aligned after Swift springs/ bilsteins and 30mm RCA installed. Went to discount tire and had them re-balance all four wheels. Stated that I was getting steering shake and could he tell that to the tech. Done and the tech tells me that all the wheels were off balance
This had been my 3rd time i've had the wheels balanced by the same discount tire and all those times it shook. He also told me I had a slight bend in my pass front wheel and that the shake would still be there.
I remembered the large pot hole I hit on the highway the day prior so I knew that had not been the cause of the shake.
Took the car on the highway and smooth as glass. This paired with the steering ecu and bracing the lower steering column shaft the car rides excellent. A pleasure to drive.
Old 05-16-13, 05:12 PM
cmara2k9
cmara2k9's Avatar
My girl loves it STIFF..................But seriously, I like the steering stiff eventhought it's a 300 it's still a 98 so I would assume it's the same idk, most threads on here complain about the steering being too loose, you should consider yourself lucky
Old 05-16-13, 10:11 PM
ThomasGS4
ThomasGS4's Avatar
I have a '98 GS400 with a production date of 1/98. The steering is stiff at low speeds too.
Old 05-17-13, 06:17 PM
mccrimmon
mccrimmon's Avatar
Same here. Low speed, the steering is stiff and sometimes it takes two hands (I'm really strong... really). I don't have any vibration or shaking at high speeds though.
Old 05-17-13, 07:42 PM
RamAirRckt
RamAirRckt's Avatar
Same here, no vibration (I did steering rack bushings recently, but still never had vibration), mine's just stiff (firm). Not bad, just not one finger steering like the 99-00 GS owners seem to complain about.
I flushed the power steering and put in Amsoil ATF. I pumped the Royal Purple out, filled with Amsoil, ran it and turned wheel back and forth and did it again 2 more times. So it is pretty red color now, got the black looking RP out....
Will see how it does now.
Old 05-17-13, 08:03 PM
tmf2004
tmf2004's Avatar
installed my Daizen sway and steering rack bushings tonight.. definitely can notice a difference but the 60mph shake/vibration is still there...
Old 05-17-13, 11:33 PM
RamAirRckt
RamAirRckt's Avatar
Silly question, be careful of course, but at 60 mph with the vibration, does it occur still in turns? If the wheel turns, does it change?
Old 05-18-13, 05:15 PM
cmara2k9
cmara2k9's Avatar
People always talk about the vibration but I've never experienced it unless a suspension part was going bad
Old 05-18-13, 11:17 PM
DMPesso
DMPesso's Avatar
I think the stiffness at slow speeds is related to the the steering getting stiffer when no RPMS are revved probably because the power steering pump. Anyone change this and still have this problem?
Old 05-19-13, 12:12 AM
RamAirRckt
RamAirRckt's Avatar
I flushed the Royal Purple PS fluid out yesterday and put in Amsoil ATF, I think it is a little easier at low speeds, but still normal feeling at high speeds.
It is very hard to make a claim because I can't easily make a ABA compassion.
Either way, I think it feels better at least.
Old 05-19-13, 12:26 AM
1QWKGS4
1QWKGS4's Avatar
I must be in the minority cuz I don't have stiff steering or steering wheel shake at all in both my GS's. The only time it felt stiff is when I had the L-tuned steering ECU installed, but since I had coilovers I took the L-tuned out and car suspension and steering feel is perfect.
Old 08-19-13, 08:30 PM
daddyduke
daddyduke's Avatar
So how do u fix this
my steering is stiff all the time .
FLexIS350F
01-17-23 10:47 AM
WILLIAMBLR
07-01-18 03:08 AM
maverick99
10-22-16 08:02 AM
Ahheck01
Suspension and Brakes
12-30-14 12:38 PM
dannieboiz
07-17-04 10:02 AM
Quick Reply: Steering stiffness and Steering ECU?
