Need some Help with CEL code
Old 05-07-13, 04:22 PM
O1GS43O
O1GS43O's Avatar
Default Need some Help with CEL code
now i searched and found stuff on this code for a gs300 and 400 but none for the 430. let me know what you guys think thanks
the other night my girl was leaving school and the cel and vsc and vsc off light came on and she said the car wouldnt go anywhere when she hit the gas (safe mod) or what ever you call it she turned the car off and restarted it and it drove home fine i pulled the codes and it was a p1121 code so i reset the codes to see if it would pop up again or if it was a fluke. drove fine to the theme park but... when we got on the hi way lights came on again and went into safe mode so i clicked in into neutral and shut it off and restarted it drove fine after that got home same p1121 code.
Old 05-07-13, 05:58 PM
porn-adkt
porn-adkt's Avatar
SEarch p1121 code... End of story
Old 05-08-13, 09:09 PM
harman
harman's Avatar
Sure you found this out already-
A member on here- MD99SC300- had this issue a while back and it turned out to be the Accelerator Pedal Position Sensor
P1121
Possible causes
- Electric throttle control actuator harness is open or shorted
- Electric throttle control actuator circuit is open or shorted
- Faulty electric throttle control actuator
When is the code detected?
Electric throttle control actuator does not function properly due to the return spring malfunction or throttle valve is stuck open
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- No throttle pedal response
Old 05-09-13, 10:07 AM
GS4_Fiend
GS4_Fiend's Avatar
google is your best friend.
paulito
02-04-19 09:48 AM
denIS200
11-08-09 01:02 PM
CallmeQ
GS - 1st Gen (1993-1997)
09-26-09 12:19 PM
j.tom
09-07-07 05:15 PM
Quick Reply: Need some Help with CEL code
