Projector Lights on 02 Lexus
Old 03-15-13, 01:21 PM
GSLex87
GSLex87's Avatar
Default Projector Lights on 02 Lexus
Hey fellas, new member here, with my simple question. Looking at some aftermarket headlights for my LEX. But all the ones I have seen say "not for gs300 with factory HID's." Does that mean HID's will not work with the housing or that means that it won't fit gs300 with HID's already in them
Old 03-15-13, 01:46 PM
TigerBrand
TigerBrand's Avatar
it won't fit gs300 with HID's already in them. The ebay projector headlights come with an hid kit with re-based bulbs. The harness is made to fit halogen ones. If your GS has factory HID's then you have d2r bulbs.
Old 03-15-13, 03:34 PM
GSLex87
GSLex87's Avatar
thanx bro. Anyone happen to kow what type of bulb or kit I need (EX: 9005,9006, h1 etc, bi xenon?
Old 03-16-13, 05:07 AM
MrG4Life
MrG4Life's Avatar
If you have factory halogen bulbs 9006 is your low beam and 9005 is your high beam.
Old 03-16-13, 09:30 AM
Mr Jokster
Mr Jokster's Avatar
You should just do it right and do a retro fit. Wont look cheap and be REAL projectors with proper output and cutoff.
just sayin.
Old 03-17-13, 10:17 AM
haroon18
haroon18's Avatar
Is there anyway to redo the harness to fit stock hid's.
Old 03-17-13, 11:03 AM
Mr Jokster
Mr Jokster's Avatar
After thinking about it... If you can find which wire from the factory harness going IN to the ballast is power and ground, you can buy some pin terminals to stick in there and run a wire from there to aftermarket kit. Seal the harness all up though when done.
Or better yet, find someone with burnt oem ballasts and cut the harness off of them and make your OWN plug and play harness for the aftermarket kit
Old 03-17-13, 12:01 PM
excluesive
excluesive's Avatar
they have D2R to 9005 and 9006 harnesses dont they?
Old 03-17-13, 01:15 PM
Mr Jokster
Mr Jokster's Avatar
I would love to see what 20,000 volts would do to a halogen bulb LoL
Old 03-17-13, 04:19 PM
excluesive
excluesive's Avatar
i think i misunderstood the intent of this thread, hence my comment not making any sense.
with that being said... i would love to see it too!
Old 03-18-13, 03:54 AM
jeepandlex
jeepandlex's Avatar
I retro fitted gs400 green tints into my 98. the factory bulbs were ds2's.....but regardless, you can hook up a ebay HID kit to them. get a relay kit too. YOu will loose self leveling, but if you aim them I don't think you will even notice. Dont get the ebay projectors tho.....the cutoff is terrible.....and IMO I dont care for the "rice" rings.......Egads!!
Old 03-18-13, 08:14 PM
Mr Jokster
Mr Jokster's Avatar
I think you need to re read the original post.
johnsonand
07-02-15 12:13 AM
m32
13
02-20-15 11:24 AM
BooBooGS
02-04-13 09:20 AM
bahiaz
Lighting
03-04-03 07:11 PM
zohaib420
05-30-01 05:12 PM
Quick Reply: Projector Lights on 02 Lexus
