Front End Passenger Side Pop
Alright here we go.. Lower Ball Joints and Outer Tie Rods were replaced last October with Moog. Caster Arms were replaced last year also with FIGS Spherical Bushings.. OEM Struts are still good..
Any ideas? It's only the passenger side. Just greased the LBJ's today, took it for a test drive after and it's still there.
Only makes the noise when going over bumps (sometimes), going up or down an incline and when braking. Pads/Rotors have been replaced also.
I'm thinking the lower control arm?
Also check to see if UCA is tight. My car used to have a click when going over bumps and stopping. Turned out to be a loose UCA, simple I know. Bought it like that seller said it was a bad shock.
hmm, i remember cinching them down pretty hard. because i remember taking them off to swing the arm to get room for bolts on the ball joints. i need to jack her up and just tighten every bolt i see.
Hey man, on a slightly different subject "LuxuryGS3" I installed the coilovers and was very solid. Seems about a week after the front drivers side makes a creaking sound when i slow down and turn just a little bit. I saw that the coilovers may need grease but they have to be removed to do it? that would suck unless you have any other experience with this...
LuxuryGS3, I see you have the Figs spherical bushing arms. Can you tell us how they're working for you? Do you think they are something you can daily drive? One last question. Did the car's tendency to wander stop? Thanks for your feedback.
As far as wandering, what do you mean? Caster arms won't deal with the car wandering. Do you mean your rear sways when you hit a bump? Need a bit more info on that.
