Easiest way to get a little more camber
Old 02-12-13, 01:16 PM
John9689
John9689's Avatar
Default Easiest way to get a little more camber
Hey guys,
wondering what is the easiest way to get just a tiny bit more camber on the rear of my car, its currently maxed out on the stock adjustment and the rear arch sits on the tyre when im aired out. I would really like it to tuck a little if possible and i cant really afford fender work at the moment
http://www.flickr.com/photos/john_shears/8467379231/http://www.flickr.com/photos/john_shears/8467379231/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8463154024/http://www.flickr.com/photos/john_shears/8463154024/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8467378739/http://www.flickr.com/photos/john_shears/8467378739/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8442774266/http://www.flickr.com/photos/john_shears/8442774266/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8383416219/http://www.flickr.com/photos/john_shears/8383416219/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8383426995/http://www.flickr.com/photos/john_shears/8383426995/ by http://www.flickr.com/people/john_shears/, on Flickr
Old 02-12-13, 01:21 PM
AVSRacing
AVSRacing's Avatar
spc rear camber kit? I got like -2.1 camber from it. so you can get even more since you have air. any pics of it with air up? I curious to see how much the wheels poke out at driving height.
Old 02-12-13, 01:23 PM
John9689
John9689's Avatar
isnt the SPC kit to correct the camber back to original specs? i need more negative
http://www.flickr.com/photos/john_shears/8421840118/http://www.flickr.com/photos/john_shears/8421840118/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8420740617/http://www.flickr.com/photos/john_shears/8420740617/ by http://www.flickr.com/people/john_shears/, on Flickr
http://www.flickr.com/photos/john_shears/8421695476/http://www.flickr.com/photos/john_shears/8421695476/ by http://www.flickr.com/people/john_shears/, on Flickr
Old 02-12-13, 01:28 PM
Advil4u
Advil4u's Avatar
preeeeeeeeeeety look insto megan lca
Old 02-12-13, 01:29 PM
Advil4u
Advil4u's Avatar
lucky u got headlight washers
Old 03-08-13, 01:18 PM
John9689
John9689's Avatar
Anyone got any other solutions? Has anyone slotted the hole in the lower control arm to get a bit more camber? It's only the tiniest little bit now
http://www.flickr.com/photos/john_shears/8384486208/http://www.flickr.com/photos/john_shears/8384486208/ by http://www.flickr.com/people/john_shears/, on Flickr
There's really nothing available for these cars in the UK, importing stuff means paying import duty which is like an extra 20%
Old 03-08-13, 02:26 PM
Debonair
iModerate
Debonair's Avatar
FIGS MEGA VIP KIT IS300/GEN2 GS 300/400 SC430
"This kit includes VIP LCA toe and trac link can achieve up to -10 degrees of camber."
Old 03-08-13, 02:29 PM
1sWt2GS
1sWt2GS's Avatar
beat me to it
Old 03-08-13, 06:55 PM
youngs3oo
youngs3oo's Avatar
^that FIGS kit looks pretty good. It can go to -10 degrees in camber. Too bad I just got laid off too...
I never knew Megan had LCAs though. OP you can check out battleversion.com if you haven't yet.
Old 03-08-13, 07:07 PM
RoninEng
RoninEng's Avatar
Spc kit is dirt cheap
I have 2.5 neg camber in rear and shaved my own fenders
It's the cheapest and easiest way with a little work
Old 03-08-13, 07:26 PM
5t341th
5t341th's Avatar
spc kit is for stock cars. do you have spacers on there?
get a rear rca kit. cheapest route
Old 03-09-13, 12:29 AM
nGooo
nGooo's Avatar
Originally Posted by John9689
Hey guys,
Untitled by john_shears, on Flickr
SM001631 by john_shears, on Flickr
image by john_shears, on Flickr
IMG_9348 (19 of 32) by john_shears, on Flickr
IMG_9340 (12 of 32) by john_shears, on Flickr
second picture and down looks good. id leave it. but if you want something to help id recommend the RUCA from battle version http://battleversion.com/store/gs-97-05/
im not sure if you want your wheels to poke out more from the bottom but with RUCA you can pull in the top.
Old 03-09-13, 03:36 AM
abounly
abounly's Avatar
Rear upper control arms. Easy -8/9
Old 03-09-13, 07:24 AM
youngs3oo
youngs3oo's Avatar
I've seen some posts where RCLA were recommended in getting more negative camber in the rear. How does it compare with the Rear Upper Control Arm? Which would you guys suggest?
Old 03-09-13, 11:01 AM
Revive
Revive's Avatar
^ Rear lower arms are primarily for camber correction, and use the upper control arm as a sort of pivoting point which does little to nothing for fender clearance.. If you are looking for more fender clearance then you need to go with RUCA's.
Quick Reply: Easiest way to get a little more camber
