How to remove glove box light w/o breaking it
Old 02-07-13, 06:18 AM
subzero32
subzero32's Avatar
Default How to remove glove box light w/o breaking it
So how do I remove the glove box light bulb (size 37) without breaking it? It's recessed and hard to grip with your fingers. I thought about pushing it out from behind with a small dental instrument (I'm a dentist). Also the footwell lights are hard to grip as well. I'm doing a LED conversion and these are the last ones I need to change.
Old 02-07-13, 07:20 AM
SPRTNYDSN
SPRTNYDSN's Avatar
it easy but its safer if you just unscrew the 4 and the one below the glovebox so you have better access to the light.
Old 02-07-13, 10:10 AM
Debonair
iModerate
Debonair's Avatar
Break it then pull it out by the filament with needle nose pliers. Worked good for me.
Old 02-07-13, 10:23 AM
subzero32
subzero32's Avatar
I want to avoid breaking the bulb but it's good to know you were able to pull it out by the filament.
Old 02-07-13, 11:53 AM
wbmx1981
wbmx1981's Avatar
Follow the steps to remove the passenger servos. There are steps to remove the glove box, its simple.
Old 02-07-13, 06:18 PM
99 GS3
99 GS3's Avatar
You might be able to kinda scoop it out with an explorer by slipping it under it, but needle nose pliers work fine. If you wrap some electrical tape around the needle nose tips it will allow you to squeeze a bit harder before breaking the bulb.
I was able to put a standard 194 in the glovebox by just trimming the bulbs base down on the sides and bending the leads a little bit, took a few minutes and a few test fits but it fit fine.
The footwells I used sqaure 9 smd led boards which put out a way better pattern than the 194 I used first did. You'll need to cut the wire feeding these lights and splice in a new bulb type for most choices to use there. These boards I used fit perfect behind the clear lens still as well.
Old 02-08-13, 06:48 AM
Debonair
iModerate
Debonair's Avatar
I was gently trying to get it out whole with some rubber tipped needle nose pliers. I failed and it broke. Those small bulbs can be stuck pretty good.
Old 02-08-13, 09:48 AM
subzero32
subzero32's Avatar
Great idea! What site did you order the 9LED board from? And what connector type did you splice in?
Old 02-08-13, 09:59 AM
MikeFoxx
MikeFoxx's Avatar
Anytime i had issues pulling smaller bulbs i've used a piece of rubber grip. The stuff some people line their kitchen cabinets with from the dollar store. It comes in handy for grip situations.
Old 02-08-13, 10:43 AM
subzero32
subzero32's Avatar
I finally got the bulb removed. I pushed it out of the housing which I pulled from the glove box. Now I'm going to put this led in there.
http://www.vleds.com/bulb-type/minia...-pair-b-o.html
Old 02-08-13, 12:11 PM
1sWt2GS
1sWt2GS's Avatar
i did this, had my sister with little fingers pull out the bulb for me
and then when i installed it, the polarity was reversed, so i had to do it a second time!
does anyone know why the glove box light doesn't light up if the keys not in the car and on AC mode tho? annoys the heck out of me when i need to get something out of the glove box.
Old 02-08-13, 04:15 PM
JeffTsai
JeffTsai's Avatar
The trick I do is to wrap some duct tape around the bulb, and then pull it out with needle nose pliers
Old 11-25-14, 12:41 PM
Seadaddy
Seadaddy's Avatar
OK. Able to get the bulb out OK, but since I can't actually see into where the bulb sits, I can't figure out where the slot is that the bulb fits into. Anyone know how to see or know this, can't see the slot.
Old 11-25-14, 03:50 PM
Revive
Revive's Avatar
Plastic fuse puller.
Old 11-26-14, 06:28 AM
Seadaddy
Seadaddy's Avatar
Thanks but not sure if this is an answer to my question as to how to see or know where to actually place that glove box bulb
Quick Reply: How to remove glove box light w/o breaking it
