2003 GS300 rear Brakes
Does anyone know what the procedure is for replacing the rear brakes on a 2003 GS300? I have noticed there is not much area to inspect the pads and mine are squeeling some in reverse.
There is a LS DIY of the rear brakes on here it is very similar to that.I suggest you take pictures off the pins holding the brakes in place so you can make sure you put them back in right. I would also suggest a impact wrench it makes life a lot easier than just using a ratchet.
My 99 GS has a pin that slides out and the pads just slide in and out to replace. It's not like the front where the calipers have to be loosed to take the pads out. Remove the wheel and you will see the pin held on by a clip, the pads hace two holes in them.
tiguy99 (08-22-17)
