P1349 Code - VVT System Malfunction
Old 09-05-12, 09:36 PM
Eric00GS3
Eric00GS3's Avatar
Default P1349 Code - VVT System Malfunction
Car runs just fine on the freeway, but is idling rough (sometimes dies) when stopped. Pulled a P1349 code. Mechanic says the OCR filter is clean, there is no sludge, and the solenoid is operating smoothly. He said that the intake VVT cam gear (which I assume from searching CL refers to the VVT controller assembly) is stuck in the up position and needs to be replaced. A few questions:
1) Is the VVT cam gear the VVT controller assembly?
2) How do you replace the VVT controller assembly?
3) Based on the symptoms I described, does the mechanics diagnosis seem correct?
Thanks in advanced.
Old 09-07-12, 07:53 AM
Eric00GS3
Eric00GS3's Avatar
Bump!!!!!!
Old 09-07-12, 09:11 AM
GS4_Fiend
GS4_Fiend's Avatar
You must replace the solenoid. Cleaning it doesnt work
Old 09-07-12, 10:08 AM
Eric00GS3
Eric00GS3's Avatar
The mechanic said the solenoid is fine. Are you suggesting that replacing the solenoid will fix my problem?
Old 09-07-12, 08:16 PM
GS4_Fiend
GS4_Fiend's Avatar
How does he know it's fine? Applying power to the solenoid doesnt necessary confirm that its good.
Old 09-07-12, 09:24 PM
Eric00GS3
Eric00GS3's Avatar
That's true. I was just going off what he was telling me.
Does anyone know another name for the VVT cam gear? Or even better, how to replace it? I looked at the factory diagrams and don't see it.
Old 09-08-12, 08:50 AM
Hardrvin
Hardrvin's Avatar
Solenoid failure is super common. I think I've heard of 1 cam gear ever failing. Hence why you can't find info on it
Solenoid is under 150 and is easy to replace.
Old 09-08-12, 10:03 AM
GS4_Fiend
GS4_Fiend's Avatar
The VVt cam gear is the camshaft. The solenoid controls the oil flow to the camshaft
Old 09-08-12, 11:24 AM
Eric00GS3
Eric00GS3's Avatar
Ok, so then the mechanic is saying that the camshaft needs replacing?
Something's not adding up because according to some of the other threads I found, the things that need replacing with a P1349 code are:
1.Valve timing
2.OCV
3. VVT controller assembly
4.ECM
As far as I can tell the camshaft is not on this list. Unless the VVT controller assembly is the camshaft/cam gear. Can someone clarify what the VVT controller assembly is?
Old 09-08-12, 12:59 PM
GS4_Fiend
GS4_Fiend's Avatar
Assuming the camshaft gears are fine. I would say the solenoid is defective. It is common
Old 09-09-12, 04:52 PM
Eric00GS3
Eric00GS3's Avatar
Bump!!!!!!
Old 09-10-12, 09:23 PM
Eric00GS3
Eric00GS3's Avatar
Anyone else? Someone must know about this.
Old 09-11-12, 06:08 AM
cmara2k9
cmara2k9's Avatar
when i had that code it was the ocv but it could be a few other things too
Old 09-12-12, 04:20 AM
Hardrvin
Hardrvin's Avatar
1.Valve timing
2.OCV
4.ECM
The controller is the cam gear. It's pretty straight forward to change as well.
If you can change a timing belt without thinking about it, then a cam gear is no problem.
Old 09-12-12, 09:58 AM
Eric00GS3
Eric00GS3's Avatar
Great thanks. Does anyone have the instructions on how to replace the VVT controller?
Quick Reply: P1349 Code - VVT System Malfunction
