Bad idle and no dash lights
hello everyone new to the boards here i recently traded upto a 99 gs300. since ive bought the bone stock gs300 i have slammed it on tein coilovers and Black 2crave wheels and tinted windows. when i bought the car it had 200,000 miles and last week i was on the freeway and i lost oil pressure and the bottom end started knocking pretty badly.
i was contemplating a gte swap but i already have my race car and i just need my daily back. so any who i ordered up a new engine from one of my reputable vendors that i use for my shop. and 1 day later here i have a 03 is300 engine.
i swapped the motor out yesterday in the process i did a timing belt waterpump and alot of little gaskets, there were alot of broken connectors on my engine harness so in the process i repinned a few plug ends. so a few hours later the engine was in the car i used the is300 intake manifold is300 injectors,ignition coils. other than that everything is from my factory motor. so i was doing some reading bout the IS manifold that it was not the same so i swapped that back to my original intake manifold so now the only pieces that are from the IS is the fuel rail with injectors and ignition coils i was going to use the original coils and injectors but all my injectors were cracked and broken.
now the car doesnt like to stay running and i have no dash lights, no power to the obd port and cannot release the shift lock a]or pop the trunk and fuel door.
it sounds like a fuel problem to me so i was thinking these injectors are either bad or will not work with my setup any ideas?
i have checked the 40A main in the kick board and the 40A main under the hood they are fine
can anyone shed some light??
thanks a alot
thanks a alot
Hey so you've put injectors off of 03 IS300 onto ur old 99 GS300 block?? Did they fit? From what i heard is that the 2JZ engine stayed the same as off 98 both IS and GS but sensors , manifolds, injectors changed as years passed? I need to change my injectors on my 98 gs300 and was wondering if they r interchangeable, if i could take it off of 02 IS300?? If anyone got an anwser for that it would be alot of help.
i ended up using the is300 injectors i just rebuilt them with a seal kit from ebay for 35 bucks. the injectors seem to work fine i did notice they did have different part numbers between my old injectors and these ones but all my GS ones were toast so i used the IS the car runs great now i had a leak at one of the injectors i found. but i pulled the the plugs and it doesnt seem to be running lean. but i do not have a wide band so i am not to positive
whh333
02-01-18 04:43 AM
