Who's running 20x8.5 et/offset 30 fronts????
Old 07-22-12, 07:15 PM
02msmg3
02msmg3's Avatar
Default Who's running 20x8.5 et/offset 30 fronts????
Found a set of staggered rims I'd like to pick up ( I've tried search and no luck so far plus it's late lol) fronts are 20x8.5 et30 with 245/35s and rears are 20x10 et45 with 285/30s. I know the rears will fit because the offset is 45(safe) my question is will the fronts fit/clear the brakes and/or fenders?? Will the 245/35s work or will a 30series tire be needed?? Are fender mods needed?? Car isn't lowered yet but will be soon on coilovers. Thanks in advance...:thumbup
Old 07-22-12, 07:52 PM
AVSRacing
AVSRacing's Avatar
Im on 20x9 30 offset in the front with 235/30/20, used to be on 255/35/20 and rubbed with front fender liner on large turns. but so far with my current set up Ive had no problems. but I'm also not lowered yet
Old 07-23-12, 08:19 AM
02msmg3
02msmg3's Avatar
Anyone else???
Old 07-23-12, 08:25 AM
vwynn
vwynn's Avatar
itll fit.. doesnt sound aggressive much.
i had 19x9 +30 front (hidisk) and i had plenty of room from rim n fender
Old 07-23-12, 09:09 AM
02msmg3
02msmg3's Avatar
Thanks vwynn, but with your 19" I'm sure you only had like a skinny 225/35, my fronts are 245/35 and 20"... That's a big sidewall!!
Old 07-23-12, 10:52 AM
vwynn
vwynn's Avatar
crap. totally neglected the tire size LOL.. my bad.
i was running 235/35/19 front. indeed your tire size is larger than mine and well larger than OEM. I wouldnt recommend going outside the OEM OD size.
why not run a 30 aspect ratio?
Old 07-23-12, 06:08 PM
Kyle Harty
Kyle Harty's Avatar
You'll have some rubbing with the 245/35 on there, at least if you're lowered (which IMHO you really should be before putting wheels on). A 225/35 tire will mostly solve the rubbing problem without "real" fender mods. I heated and bent the plastic fender liner in a few spots along the top of the arch and don't have any significant rubbing. They're not real aggressive but the 245 tire will be a problem in my experience.
Lakersfan
12-01-16 10:03 AM
Salil022
11-07-16 03:41 AM
Den350
09-29-15 01:43 PM
msgs350
03-26-12 04:12 PM
questnyc
05-21-08 11:34 PM
Quick Reply: Who's running 20x8.5 et/offset 30 fronts????
