Trunk not opening from panel or remote!! Please Advise
Old 05-17-12, 04:21 AM
duly
duly's Avatar
Default Trunk not opening from panel or remote!! Please Advise
My truck of my 2004 Gs300 is now only opened by using my key unlocking trunk lock. It wont open with the remote or from inside the cabin panel button. Has this every happenned to any of you guys. TIA
Old 05-17-12, 06:15 AM
JamesV
JamesV's Avatar
Default strange
i am having a similar problem. but i cant open mine if i try and use the key. it will only work if i use the button on my key.
Old 05-17-12, 07:20 AM
ThomasGS4
ThomasGS4's Avatar
Your GS has a truck?!
Old 05-17-12, 08:33 AM
ninja6o4
ninja6o4's Avatar
^^^ lol nice gif
Old 05-17-12, 09:55 AM
perry05g35
perry05g35's Avatar
I'm having the same problem as well as of today. However check and make sure that you didn't engage the trunk lock inside the car below your emergency brake.
Old 05-17-12, 08:08 PM
KingNasGS4
KingNasGS4's Avatar
check your trunk lock
Old 05-17-12, 08:16 PM
AM21GS400
AM21GS400's Avatar
Yeah check the trunk lock, lol you might have accidentally pressed the little silver lock button, just unlock it with your key, its right above the trunk and gas switches
Old 05-18-12, 01:00 PM
L3XOTIC
L3XOTIC's Avatar
Yep, check the button because i had the same issue after getting my battery replaced. They had switched the button somehow.
Old 05-18-12, 02:49 PM
perry05g35
perry05g35's Avatar
Took my car up to the dealership $70s to fix the problem which was due to heavy pressure as in someone sitting on the trunk will cause the locking latch to get stuck. I had my RMM spoiler installed and noticed that I couldn't open my trunk afterwards then a couple days later it opened with no problem. 2 weeks later same problem due to me putting force on my RMM spoiler because the heat we had in San Antonio caused my double sided tape to lose it's hold in a couple spots.
sgmorton
09-06-14 11:11 AM
Yoshiii
21
11-25-13 03:21 PM
DKGS4
02-17-09 10:17 AM
omniskye
09-28-08 05:21 PM
Levistey0
SC- 1st Gen (1992-2000)
10-05-04 01:04 PM
Quick Reply: Trunk not opening from panel or remote!! Please Advise
