GS4 exhaust leak?
Old 05-09-12, 05:17 AM
RamAirRckt
RamAirRckt's Avatar
Default GS4 exhaust leak?
Search found nothing.... What are common exhaust leaks on the 1UZ-FE?
Old 05-09-12, 09:09 AM
GS4_Fiend
GS4_Fiend's Avatar
Common places would be at the flanges or the exhaust manifold and gaskets.
Old 05-09-12, 09:10 AM
GS4_Fiend
GS4_Fiend's Avatar
Another tip exhaust leaks before the cat you will smell bad smell of fuel and after the cat you wont have any weird smell but just a muffle sound
Old 05-09-12, 09:17 AM
RamAirRckt
RamAirRckt's Avatar
No smells, just a just raspy sound from what sounds like dead center under car. Getting progressively worse. Are parts available still or or aftermarket the better or only way to go?
My friend who works at a Lexus dealer just emailed:
"Look behind the CATS on the Y pipe. Look at the clamp area that holds the heat shield on the pipe. They tend to rust out there."
Old 05-09-12, 10:29 AM
abounly
abounly's Avatar
I know my heatshield is lose. Rattles all the time
Old 05-09-12, 10:33 AM
GS4_Fiend
GS4_Fiend's Avatar
Then look after the cats all the way to the mufflers
Old 05-09-12, 03:46 PM
jp196400
jp196400's Avatar
my Y pipe is leaking right where it comes together, you might want to look there
Old 05-09-12, 06:59 PM
newgsman
newgsman's Avatar
Yup, my y pipe rusted out, in the same area. Was sounding raspy at first then after a while was quite throaty
Old 05-09-12, 08:05 PM
RamAirRckt
RamAirRckt's Avatar
What did you do to fix? Muff shop or ?
Old 05-10-12, 08:37 AM
newgsman
newgsman's Avatar
Couldn't find any aftermarket at the normal muffler shops so I went OEM. I think it was less than $500 iirc. It came complete with new heat sheilds. I figured it should last me another 10 years. Usually the muffler shop stuff is only good for a few years up here in the salt bed of the world.
I think what happened with the original is that the the salt and crud would build up in and around the heat shield causing accelerated rotting. Hard to decide if it is better to remove the shields on the new one also. All the y-pipe not covered by the heat shields was still very solid.
Old 05-10-12, 10:33 AM
RamAirRckt
RamAirRckt's Avatar
Any chance there is pictures of it out there on the net? I would like to see what I am up against.
Is it in a place that a good muff shop can actually weld up a worthy repair on it?
Old 05-11-12, 09:45 AM
13loody
13loody's Avatar
My y-pipe had a hole in it when I first bought the car. Had a cheap muffler shop make a new one. Unfortunately I couldn't find a shop with mandrel pipes. I read somewhere that Lexus y-pipes were actually very well designed for the GS400 and to stick with the stock pipes.
Right now it's the flanges connecting to the cats that have a very small leak. Lucky for me it's not throwing a code for that.
Old 05-11-12, 11:04 AM
GS4_Fiend
GS4_Fiend's Avatar
Either way you cant do it yourself. You are gonna need to take it to muffler shop anyways
Old 05-11-12, 01:48 PM
repugnante
repugnante's Avatar
is it a rattle/raspy tone below 2000 rpms?
Old 05-11-12, 01:50 PM
RamAirRckt
RamAirRckt's Avatar
it only bothers me now in drivethru (raspy and reflects off the building walls)..... Else just adds some growl to the cruise. Not objectionable at all.
Quick Reply: GS4 exhaust leak?
