DIY Door Lock Actuator
Old 05-01-12, 07:46 PM
timtim14
timtim14's Avatar
Default DIY Door Lock Actuator
I recently swapped out my door lock actuator motor by hand and used these video's as a guide. I have a 99 Lexus GS 400 and definetly worth the time if your interested in saving $140. I caution to take your time with splitting the actual case that houses the motor and gears. I did this by using a razor blade to first get a slit started to get a putty knife in there. Be carefull when it is apart not to drop the case or the revolving gear can fall out with the spring.
This is where i purchased the motors. So far so good. http://myworld.ebay.com/mopselectric...id=p4340.l2559
This is video 1
Video 2 www.youtube.com/watch?v=5VqGy7_X9MM
Old 05-01-12, 10:09 PM
PUREADDICT
PUREADDICT's Avatar
Dope, thanks for supplying a DIY video. Will be doing this when my sched clears
Old 05-01-12, 11:10 PM
5t341th
5t341th's Avatar
good stuff. if mine ever goes out, ill look for this. thanks
Old 05-02-12, 11:43 AM
sakataj
sakataj's Avatar
yeah like most other things the noobs post this was supplied awhile ago in this thread
https://www.clublexus.com/forums/gs-...ators-diy.html
i posted it in Post # 473 almost 2 years ago (tomorrow it will be 2 years)
OP please search 99.9% of everything with our car has been posted up already
Old 05-02-12, 11:47 AM
abounly
abounly's Avatar
That video does unnecessary steps. You'll be wasting your time following his steps
Old 05-02-12, 12:09 PM
13loody
13loody's Avatar
Don't need to be so harsh. If his post helped one person it's of value. The DIY door actuator sticky has 50+ pages and some people don't have time nor want to spend the time reading through all that.
As for the videos, there are some unnecessary steps, but instead of saying you'll be wasting your time, why don't you tell him what steps he can skip, ie. leave the window rolled up and you don't have to remove it.
Just my opinion though.
Old 05-02-12, 12:40 PM
abounly
abounly's Avatar
To take off the Front door actuators, 2 clips and 5 bolts. 4 T30 bolts and 1 that holds the window sill then it should slide out.
I mean it did help back then, but after doing it myself I think its a waste of time to take out the door handle and window and whatever else he did.
Old 05-02-12, 02:02 PM
GS4_Fiend
GS4_Fiend's Avatar
Actually video is better. Dont need to flip through pages. But we must give this guy some credit. Hes a new member
Old 05-02-12, 02:08 PM
1sWt2GS
1sWt2GS's Avatar
u suggest trying tochange the motor before u do the actual actuator?
Old 05-02-12, 02:19 PM
sakataj
sakataj's Avatar
the video was already posted re-read my post.
john u r so funny....so because people are to lazy to look through a thread or to find old threads we should just post everything up new? lol...im gonna go back into stealth mode like i been the last week.
Old 05-02-12, 02:40 PM
01LEXPL
01LEXPL's Avatar
^ respectively, this forum sucks **** for searching anything concrete.
Generic stuff still pulls up oodles and oodles of threads. There's no plug-ins or updates to the search for this version it seems. This is the only forum i visit still running this layout and software.
I have threads [of mine] that i've searched knowing where they were and the board search won't pull them up...
Old 02-06-13, 08:00 AM
lexuspcl88
lexuspcl88's Avatar
Thumbs down Lexus GS 300
The year of my lexus GS 300 is 2005'
I want tok woof the door locks r supposed to lock automatically when u drive off.
Mine does not lock as I noticed to yhorrorsome time ago.
Lexus cl88
Old 02-06-13, 08:05 AM
lexuspcl88
lexuspcl88's Avatar
Sorry I didnotcthisbefire when my actuatorwenti sent and ought one from fl USA .
I loveontrinidad and Tobago , costume a wad,$600' 00'
Did my friendwhobought it ripm
Me off,?
Then thecarcrashed and I sold it as scrap and away went thenewactuator.
Lexuspcl88
Old 02-06-13, 08:12 AM
lexuspcl88
lexuspcl88's Avatar
Thumbs down Lexus GS 300 yr 2005
hi I see a yellow tie onyr engine,
Is it necessary to put a tue rod onmy car the lexus GS 300 yr 2005.
What is the benefit ",?
Lecuspvl88
Old 02-06-13, 01:33 PM
porn-adkt
porn-adkt's Avatar
Originally Posted by ClarisaRWD
If only I had the time :/
??time forrrr??
Quick Reply: DIY Door Lock Actuator
