try this with your car
Old 03-29-12, 11:23 PM
1sWt2GS
1sWt2GS's Avatar
Default try this with your car
recently i noticed when i hit unlock twice on my 02 2gs key fob (OEM) it unlocks a third time. its never done this in the past.
can someone try it or know whats wrong? thanks
Old 03-29-12, 11:43 PM
abounly
abounly's Avatar
Happens to mine too. I think after I changed my driver door actuator.
Old 03-30-12, 12:49 AM
1sWt2GS
1sWt2GS's Avatar
so the third b is unfunctional? never noticed that in the past, i havent touched my door actuators at all.
to make it more clear
1. walk up to a locked car
2. unlock twice (consecutively, so that all 4 doors unlock instead of the driver side only)
car then blinks twice (and couple seconds later blinks again)
Old 03-30-12, 01:28 AM
abounly
abounly's Avatar
Yup! If I unlock once, its normal. If i press the unlock twice to unlock the other doors, after the 2nd beep a few seconds later another beep goes off. Dont know why,
Old 03-30-12, 01:33 AM
Bombsquad
Bombsquad's Avatar
Thats a warning indicator of sorts? I'm sure it is, but my memory fails me?
Old 03-30-12, 02:35 AM
SoCal Cyco
SoCal Cyco's Avatar
sometimes when i lock my car(only once) it relocks about 3 seconds later?
Old 03-30-12, 03:13 AM
1sWt2GS
1sWt2GS's Avatar
good to know im not alone, ive recently been noticing a lot more things about my car than ever!
Old 03-30-12, 06:16 AM
Rich27
Rich27's Avatar
I have also been having issues.
- In the morning, the car does not unlock with the remote. I have to unlock by hand. This is early in the morning before the sun is up. Maybe because its colder outside?
- Sometimes when I look the door, I don't hear the beep until about 3 seconds later. It does lock instantly, but just takes a few seconds to actually beep.
Old 03-30-12, 07:58 AM
vipXjunky
vipXjunky's Avatar
This recently happens to me... Except I have an aftermarket alarm system.. I press the lock and it beeps twice, then 3 seconds later, it beeps again. Same with unlocking. I figured out what caused it, which was a blown fuse that enabled my radio, dash lights and foot lights. I don't know of you guy have that problem, but ya can probably check the fuses.. Hope it helps.
Old 03-30-12, 08:00 AM
vipXjunky
vipXjunky's Avatar
Sorry to double post but damn, my iPhone made me sound like a total fob. Dam autocorrect
Old 03-30-12, 08:14 AM
ybbob
ybbob's Avatar
Damn, I get this same problem every time. I thought I might try changing the battery on the key to see if it helps
Old 03-30-12, 08:56 AM
NEbiker10
NEbiker10's Avatar
if you unlock it and do not open a door in like 10-20seconds it will lock it for anti-theft
Old 03-30-12, 09:23 AM
sgvGS3
sgvGS3's Avatar
I've noticed this also. Usually the first two beeps will be for all of the doors. And when it seems to make a third beep I've noticed is when one of the door locks won't open.
Old 03-30-12, 09:39 AM
GSJake
GSJake's Avatar
I bet this is what it is..
Old 03-30-12, 09:43 AM
ninja6o4
ninja6o4's Avatar
It is one of your actuators failing, and the car knows this so it tries to unlock all doors again. If you're hitting unlock only once (to unlock just driver door) and it only beeps once, it's not that one
Sit in the back of your car, lock it, then hit the unlock button twice and check the other 3 locks quickly. After 2-3 seconds it will try again if one of them didn't unlock.
Quick Reply: try this with your car
