front suspension noise low speed
Old 03-15-12, 09:39 PM
istundra
istundra's Avatar
Question front suspension noise low speed
Hi Everyone,
After i got my RCA installed and my coil overs raised, i've noticed very apparent suspension noise coming from the front while going over bumps on low speeds.
I've checked the upper strut mount if it is tight... but the sound is there. I only hear this on low speeds in parking lots while going over cracked pavement.
Anyway, while my car was being raised by the shop, i notice they did 1 or 2 turns of the preload setting... while trying to raise the car. (there not suppose to do this!!!)
Question - if they increase the preload (tighten the spring), will it cause more noise?
I believe technically when increasing the preload, you'll also get a more stiffer ride.
The noise is annoying me! it kinda sounds like the bearings on my strut mount went bad on low speeds.
Please help!!!
BTW - i got STANCE coilver, EXACT RCA, with no finger gap all around.
Thanks!!!
Old 03-16-12, 12:48 AM
newgsman
newgsman's Avatar
Not sure if I have the answer but my car used to do exactly what you describe. I had Bilstein/L-sportline setup. I did almost a complet suspension and steering do-over and the noise disappeared. Unfortunately I did everything all at once so I don't know which item was causing the noise.
I changed: shocks (KYB), springs(L-tuned), lower ball joints, outer tie rod ends, steering rack bushings, lower control arms 1&2 and passenger upper control arm, (all OEM).
No more noise, car rides very nice but there is still a very slight highway shimmy sometimes, not always.
I am thinking of putting back the Bilstein/L-sportline setup this summer. They would at least tell me if it was the shocks or not.
Old 03-16-12, 07:51 AM
justablkv8
justablkv8's Avatar
check your sway bar end links...
Old 03-16-12, 02:56 PM
try2fndmrk
try2fndmrk's Avatar
Off topic: do you raise your ride height when you install RCA? Or are you supposed to lower it?
Old 03-16-12, 04:58 PM
justablkv8
justablkv8's Avatar
With the RCA it lowers it.
Old 03-16-12, 05:05 PM
AYEmike
AYEmike's Avatar
fawk it dood, just drive faster so you can't hear it lol.
Old 03-17-12, 12:36 PM
istundra
istundra's Avatar
YOu're suppose to raise the car back up.
now i gotta get access to air tools and re-torque my strut mounts to see WTF!
kyk007
13
04-04-15 09:36 PM
ZeRoSL
05-28-13 01:28 PM
dan812
09-18-12 07:37 AM
allerton
05-19-06 08:24 PM
sonyman
Suspension and Brakes
12-15-05 10:00 AM
Quick Reply: front suspension noise low speed
