GS300 1JZ engine swap
Old 02-16-12, 01:44 AM
poledrift
poledrift's Avatar
Originally Posted by Kzoosho
After looking at videos of that car for years its finally inspired me to build one
Originally Posted by SRTGS300
I'm not sure about the angling kits for the GS, you should look up on that. As for power, I recommend just go NA-T instead of swapping especially if you're only aiming for 400ish to the wheels.
At the moment its 1jz or nothing
Originally Posted by 99 GS3
1JZ is a great engine still and potential for power, luckily the 1jz and 2jz motor mounts and oil pans are directly swappable so there are no issues there.
One of the great things about the JZ series all around is that the blocks/heads/accessories and lots of various parts are directly interchangeable. And it is done all the time for 1.5jz hybrid builds.
You could use the stock 2jz bottom with the 1jz everything else and gain the displacement back. Yeah the 2jz stock bottom won't be forged so that limits power somewhat, but NA-T would have the same limitation.
NA-T is a great route as well, can make plenty of power, but the biggest advantage of the 1JZ-GTE VVTI is that it can be had for well under 2k (and way way less in areas where they had chasers, mark II's, and soarers with stock 1jz's and they don't need to be imported) and will physically drop right utilizing stock parts on the existing motor. It is a single turbo so that you don't have to deal with the heater core clearance issues that the 2JZ-GTE rear turbo housing gives.
Either route will easily provide 400hp with minimal mods, so what ever you have most available in your area you can make something work for your build.
Thank you for the information there lad, im still undecided to go for the 1jz or the VVTI version
Originally Posted by Bippu147
smaller tighter track means you need more torque. 2J all the way
The 1jz is tried and tested in Ireland, its the job for me
Old 02-16-12, 07:04 AM
Bippu147
Bippu147's Avatar
tried and tested in a heavy car like a GS? whatever floats your boat man. It's less work and same amount of money for a 2JZ swap, and more power.....seems like a no brainer to me.
Old 02-16-12, 07:31 AM
poledrift
poledrift's Avatar
Yea there's a chaser in Prodrift and he has no problems at all with the 1jz
Old 02-16-12, 08:23 AM
Bippu147
Bippu147's Avatar
X chassis is much lighter and much more controllable than an S chassis when it comes to drifitng. I own both.
Old 02-16-12, 09:08 AM
poledrift
poledrift's Avatar
4 doors look seriously cool going sideways
Old 02-16-12, 09:16 AM
Bippu147
Bippu147's Avatar
Yep they do. But you're not going to have the same success with an S chassis, you need more power!
Old 02-16-12, 10:25 AM
Justin2JZ
Justin2JZ's Avatar
OP, what do you have against just building and boosting the stock 2J GE in the GS?
Old 02-17-12, 10:38 AM
poledrift
poledrift's Avatar
The car is going to be a rolling shell, there is no engine in it
Old 02-17-12, 07:29 PM
AristoKing
AristoKing's Avatar
You would get more torque from a 2J than a 1J... If you do it that's great but your best off with a 2J less $$$ easy swap.. You will have wiring problems since it's older technology vs. new technology.
But in the OP is your $$.
Old 02-18-12, 08:22 AM
99 GS3
99 GS3's Avatar
Of course the 2J is the best choice and the better performing engine, but that doesn't mean the 1J sucks, it's still a hard pulling engine that can make plenty of power with mild upgrades just like the 2J.
In the country the OP is in they may have 1JZ cars, that we never got here. That means they are all over the junkyard and cheap as dirt. It's comparable to the MKIII supra 7M here, I can go down to the local pick-a-part yard here an there are MKIII supra's laying in a field that I could pull the motor for only $99, now the trans an accessories are additional, so approx $300 I could get the entire running driveline, so if this is the case in the OP's country you can see why it may be desirable route to go, and for $300 a 1JZ/R154 is a hell of a combo to work with for the price.
The standard 1J is a Twin Turbo, the VVTI version is the Single turbo version. In a LHD the single turbo will make the install less crowded up against the firewall and heat core, in a RHD car the twins would be in the way of mounting a clutch master cylinder since you mention going Manual swap. The VVTI version also produces a bit more low end torque just as the 2j VVTI version does compared to it's predecessor.
I would go VVTI if you have a choice between both.
Old 02-18-12, 08:37 AM
99 GS3
99 GS3's Avatar
Here is a 1jz vvti in a RHD is300/altezza with the clutch master visible.
Old 05-18-13, 12:37 AM
GunFightr
GunFightr's Avatar
Originally Posted by Justin2JZ
Its definitely possible but you'll be better off doing a 2J swap because it bolts right up to the frame and the 1J doesnt so you'll spend as much money custom fitting a 1J than you would just swapping a 2J in.
Correct me if I'm wrong but if he gets a 1j vvti from a later model car it will bolt right up and the wiring and computer will bolt right in just as a 2J vvti would? Again with a newer model 1J vvti.
Old 05-18-13, 11:22 AM
Mr Jokster
Mr Jokster's Avatar
Wow, this is a resurrected thread....
Gsfreek
Florida Lexus Club
10-07-18 01:58 PM
CrackerBit
North Texas Lexus Club
07-02-18 05:29 PM
CrackerBit
07-01-18 09:18 PM
weedy219
11-07-08 05:08 AM
Tuning
GS - 1st Gen (1993-1997)
10-15-08 06:53 AM
Quick Reply: GS300 1JZ engine swap
