Locked out of car, Help!
My wife's civic rear door wouldn't open anymore from inside or out. We ended up having to remove the rear bench seat so that we could get at all the bolts/screws holding the door panel and thus were able to reach in and manually open the car. You will most likely have to do this as well. The bench is actually really easy to remove but it is very awkward removing the panel when the door is closed. Good luck!
It was not easy man, not sure what door yours is but mine was rear pass, I took out all the screws that I could reach then I pried the door panel away from the door with the window down and somehow was able to reach the cables (not sure what there called, long cable that unlocks door) and pull them out
