How is air ride suspensions thru winter?
Old 11-28-11, 07:28 AM
SorrGwa
SorrGwa's Avatar
Default How is air ride suspensions thru winter?
Those of you guys on air, do you drive the car through winter? hows the weather on the system?
Old 11-28-11, 03:23 PM
seivonecsu
seivonecsu's Avatar
i got a chevy silverado on air in NY that i drove last winter all my valves, tank, and compressors are oocated under the truck so the valves froze... had to be heated up with a dryer before i could drive... most lexus setups everything is located in the truck so i can't see it being a hassle because not as much water will be getting in the lines to freeze.... NO WATER IN LINES=NO FREEZING should be good to go
Old 11-28-11, 06:53 PM
lowKut
NELOC Moderator
lowKut's Avatar
This will be my first winter w/ air. I am anxious to know myself.
Old 11-28-11, 07:15 PM
vwynn
vwynn's Avatar
feels the same as summer to me... Of course i live in Cali tehehe
get some warmers in case you need to warm up your valves if they get stuck. Also take note of the salted roads n make sure you try to clean the bags here n there so it doesnt build it.... oh and Limit raising n lowering your car so that u dont need to deal with stuck valves..
Old 12-06-11, 03:39 PM
seivonecsu
seivonecsu's Avatar
stuck valves are a pain in the assss!!!!
Old 12-06-11, 03:56 PM
On3_Lo35
On3_Lo35's Avatar
rides fine in the winter, drove mine through snow and stuff....drifts pretty well too...
Old 12-06-11, 06:18 PM
5t341th
5t341th's Avatar
my valve got stuck for a little bit the other day. wasnt too cold out either, 50*
i just waited a little and it unstuck itself
Old 12-06-11, 07:18 PM
vwynn
vwynn's Avatar
maybe put some air brake fluid or watever in the tank will help?
rcfowner
RC F (2015-present)
36
04-30-19 06:58 AM
psvt
06-11-18 04:07 PM
rustednail
VIP Style
01-07-11 06:58 PM
Dima87
Chicago Lexus Club
03-05-06 01:16 PM
Quick Reply: How is air ride suspensions thru winter?
