Ive got VIBESSSSSSS
Old 10-24-11, 01:23 PM
D-Boi
D-Boi's Avatar
Quick update.
I didnt replace the inner tie rods.
I put on a pair of wheels from a forum member on here that were perfectly balanced and my car rides out smooth. However it went crazy on me today once i got on the freeway and started shaking like emily rose but then came back again.
Old 10-24-11, 01:32 PM
GS4_Fiend
GS4_Fiend's Avatar
Replace inner tie rods and LCA #2 and report back
Old 10-24-11, 02:42 PM
veritek
veritek's Avatar
Well, I was gonna ask if you had hub-centric rings on the Axis wheels, like someone else mentioned, or maybe one of the wheels has a small bend that could be throwing off the balance, but since you said it does the same thing with the stockers, and even another member's balanced stock wheels, it sounds like a suspension issue.
Old 10-24-11, 03:20 PM
D-Boi
D-Boi's Avatar
It is for sure an issue that has nothing to do with the wheels. I have had the car up in the air numerous times and there is no left or right play at all indicating a loose inner tie rod. However the car does swerve from side to side as i have to keep correcting it while on the freeway. I also hear a clunking noise when going in reverse down my driveway which initialy i thought of it being my LBJ's. However after replacing those noise is still there. As far as the LCA number 2s go is there a way i can buy just the bushings and if is daizen the only place that might have them?
Honestly the way the car is driving is making me not want to drive it at all. Kind of annoying
Old 10-24-11, 03:47 PM
OT0814
OT0814's Avatar
from what you are saying about it swerving have you tried to change your steering rack bushings? I just did it and it improved steering a lot? Also are you lowered at all? I know you dont want to throw money at it but sometimes thats the only way. There isnt any one set thing to do. Make sure your alignment is good. Ive had it come and go on me and sometimes its the alignment sometimes its the wheel balance. The reason why i ask if you are lowered is because i had a problem when i changed my damper and i guess it was uneven and my car was shaking but when i realized that the dampers were off and fixed them my car rode smoooth again.
Old 10-24-11, 03:53 PM
D-Boi
D-Boi's Avatar
Yes the car is lowered on Tanabe DF springs.
Old 10-24-11, 05:10 PM
NEbiker10
NEbiker10's Avatar
Try finding some OEM lexus wheel and see if it still shakes.
Old 10-24-11, 06:47 PM
D-Boi
D-Boi's Avatar
Ive tried 2sets of oem lexus wheels and it still has the crackhead twitches.
Old 10-24-11, 09:02 PM
GS4_Fiend
GS4_Fiend's Avatar
His problem is obviously not wheels cuz he been switching every kind of wheels out there.
Old 10-25-11, 02:03 PM
Slydewayz
Slydewayz's Avatar
Ive heard from a buddy that works at Lexus that the subframe bushings go bad in these pretty easily as well but thats just word of mouth, i myself am also experiensing the shakes but over 75 - 80mph
Old 10-25-11, 07:05 PM
GS4_Fiend
GS4_Fiend's Avatar
Do you have a pic of the subframe bushing that u are talking about?
Old 10-25-11, 08:08 PM
Slydewayz
Slydewayz's Avatar
This is what i found online, if you go onto the link and look at the picture the gs300 has 4 bushings and i was told those tend to go bad.
http://www.ebay.com/itm/98-lexus-GS3...#ht_2257wt_952
Old 10-27-11, 11:36 AM
D-Boi
D-Boi's Avatar
So i gave up trying to find out what parts are causing the vibes and went ahead and bought a few things.
1 Inner tie rods
2 Daizen control arm bushing kit (which from what ive read comes with caster and lower control arm bushings)
3 sway bar bushings
4 steering rack bushings
5 front wheel bearings
Now if i still get vibes after all this im done with it and i will more than likely take a nice smelly dookie on it.
Old 10-27-11, 12:24 PM
GS4_Fiend
GS4_Fiend's Avatar
Oh you are talking about the crossmember
Old 10-27-11, 01:05 PM
Milan
Milan's Avatar
And they looked mighty fine in my opinion lol.
Quick Reply: Ive got VIBESSSSSSS
